切换为新布局自动创建视口。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 例子工 务 局: Sub Example_LayoutCreateViewport() ' This example reads and modifies the preference value that controls ' the automatic creation of a viewport for new layouts. When finished, this example ' resets the preference value back to its original value. Dim ACADPref As AcadPreferencesDisplay Dim originalValue As Variant, newValue As Variant ' Get the display preferences object Set ACADPref = ThisDrawing.Application.preferences.DISPLAY ' Read and display the original value originalValue = ACADPref.LayoutCreateViewport MsgBox "The LayoutCreateViewport preference is set to: " & originalValue ' Modify the LayoutCreateViewport preference by toggling the value ACADPref.LayoutCreateViewport = Not (originalValue) newValue = ACADPref.LayoutCreateViewport MsgBox "The LayoutCreateViewport preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.LayoutCreateViewport = originalValue MsgBox "The LayoutCreateViewport preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_LayoutCreateViewport() ;; This example reads and modifies the preference value that controls ;; the automatic creation of a viewport for new layouts. When finished, this example ;; resets the preference value back to its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Read and display the original value (setq originalValue (vla-get-LayoutCreateViewport (vla-get-Display preferences))) (alert (strcat "The LayoutCreateViewport preference is set to: " (if (= originalValue :vlax-true) "True" "False"))) ;; Modify the LayoutCreateViewport preference by toggling the value (vla-put-LayoutCreateViewport (vla-get-Display preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true)) (setq newValue (vla-get-LayoutCreateViewport (vla-get-Display preferences))) (alert (strcat "The LayoutCreateViewport preference has been set to: " (if (= newValue :vlax-true) "True" "False"))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-LayoutCreateViewport (vla-get-Display preferences) originalValue) (alert (strcat "The LayoutCreateViewport preference was reset back to: " (if (= originalValue :vlax-true) "True" "False"))) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 03:39
