指定图层的状态。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论与关闭的图层关联的对象不会显示在屏幕上或打印。与属性不同,关闭的图层在再生期间生成,但不显示。Freeze 关闭或冻结的图层上的 AutoCAD 曲面和圆是不可见的,但在使用“隐藏”、“着色模式”或“渲染”命令时,它们仍会隐藏对象。 例子工 务 局: Sub Example_LayerOn() ' This example creates a new layer called "LayerOn". ' It then displays the status of the LayerOn property ' for the new layer, toggles the status of the ' LayerOn property, and again displays its status. ' After running this example, you can check the layer ' control on the Object Properties tool bar. It will ' show the new layer and the latest LayerOn status. Dim layerObj As AcadLayer ' Create the new layer Set layerObj = ThisDrawing.Layers.Add("LayerOn") ' Display the LayerOn status of the new layer GoSub DISPLAYSTATUS ' Toggle the status of the LayerOn property for the layer layerObj.LayerOn = Not (layerObj.LayerOn) ' Display the LayerOn status of the new layer GoSub DISPLAYSTATUS Exit Sub DISPLAYSTATUS: If layerObj.LayerOn Then MsgBox "Layer " & layerObj.name & " is turned on.", , "LayerOn Example" Else MsgBox "Layer " & layerObj.name & " is turned off.", , "LayerOn Example" End If Return End Sub Visual LISP: (vl-load-com) (defun c:Example_LayerOn() ;; This example creates a new layer called "LayerOn". ;; It then displays the status of the LayerOn property ;; for the new layer, toggles the status of the ;; LayerOn property, and again displays its status. ;; After running this example, you can check the layer ;; control on the Object Properties tool bar. It will ;; show the new layer and the latest LayerOn status. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create the new layer (setq layerObj (vla-Add (vla-get-Layers doc) "LayerOn")) ;; Display the LayerOn status of the new layer (if (= (vla-get-LayerOn layerObj) :vlax-true) (alert (strcat "Layer " (vla-get-Name layerObj) " is turned on.")) (alert (strcat "Layer " (vla-get-Name layerObj) " is turned off.")) ) ;; Toggle the status of the LayerOn property for the layer (vla-put-LayerOn layerObj (if (= (vla-get-LayerOn layerObj) :vlax-true) :vlax-false :vlax-true)) ;; Display the LayerOn status of the new layer (if (= (vla-get-LayerOn layerObj) :vlax-true) (alert (strcat "Layer " (vla-get-Name layerObj) " is turned on.")) (alert (strcat "Layer " (vla-get-Name layerObj) " is turned off.")) ) ) |
GMT+8, 2024-6-10 23:36
