指定上次使用的文本高度。 支持的平台:仅窗口 属性值只读:不 类型:双 用于文本样式的最后一个文本高度。 言论没有额外的评论。 例子工 务 局: Sub Example_LastHeight() ' This example finds the current value for LastHeight. ' It then changes that value, and resets it again. Dim txtStyleObj As AcadTextStyle Set txtStyleObj = ThisDrawing.ActiveTextStyle ' Set and retrieve the LastHeight property Dim currHeight As Double Dim newHeight As Double ' Retrieve current LastHeight property currHeight = txtStyleObj.lastHeight MsgBox "The current value for LastHeight is " & txtStyleObj.lastHeight, , "LastHeight Example" ' Set LastHeight to a new value txtStyleObj.lastHeight = 4# ' Retrieve the current LastHeight value newHeight = txtStyleObj.lastHeight MsgBox "The new value for LastHeight is " & txtStyleObj.lastHeight, , "LastHeight Example" ' Finally reset LastHeight to its default value txtStyleObj.lastHeight = currHeight MsgBox "The value for LastHeight has been reset to " & txtStyleObj.lastHeight, , "LastHeight Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_LastHeight() ;; This example finds the current value for LastHeight. ;; It then changes that value, and resets it again. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq txtStyleObj (vla-get-ActiveTextStyle doc)) ;; Set and retrieve the LastHeight property ;; Retrieve current LastHeight property (setq currHeight (vla-get-LastHeight txtStyleObj)) (alert (strcat "The current value for LastHeight is " (rtos currHeight 2))) ;; Set LastHeight to a new value (vla-put-LastHeight txtStyleObj 4) ;; Retrieve the current LastHeight value (setq newHeight (vla-get-LastHeight txtStyleObj)) (alert (strcat "The new value for LastHeight is " (rtos newHeight 2))) ;; Finally reset LastHeight to its default value (vla-put-LastHeight txtStyleObj currHeight) (alert (strcat "The value for LastHeight has been reset to " (rtos currHeight 2))) ) |
GMT+8, 2024-6-10 16:44
