指定文本着陆间距。 支持的平台:仅窗口 属性值只读:不 类型:双 文本着陆间隙。 言论没有额外的评论。 例子工 务 局: Sub Example_LeaderLine() Dim oML As AcadMLeader Dim points(0 To 5) As Double points(0) = 1: points(1) = 1: points(2) = 0 points(3) = 4: points(4) = 4: points(5) = 0 Dim i As Long Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i) Dim r As Long r = oML.AddLeader() points(4) = 10 Call oML.AddLeaderLine(r, points) MsgBox "LeaderCount = " & oML.LeaderCount ZoomExtents End Sub Visual LISP: (vl-load-com) (defun c:Example_LeaderLine() (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5))) (vlax-safearray-fill points '(1 1 0 4 4 0 ) ) (setq i 0) (setq modelSpace (vla-get-ModelSpace doc)) (setq oML (vla-AddMLeader modelSpace points i)) (setq r (vla-AddLeader oML)) (vlax-safearray-put-element points 4 10) (vla-AddLeaderLine oML r points) (alert (strcat "LeaderCount = " (itoa (vla-get-LeaderCount oML)))) (vla-ZoomExtents acadObj) ) |
GMT+8, 2024-6-11 01:01
