指定 Windows 标准键盘或 AutoCAD 经典键盘。 支持的平台:仅窗口 属性值只读:不 类型:枚举acKeyboardAccelerator
言论没有额外的评论。 例子工 务 局: Sub Example_KeyboardAccelerator() ' This example returns the current setting of ' KeyboardAccelerator. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currKeyboardAccelerator As Integer Set preferences = ThisDrawing.Application.preferences ' Retrieve the current KeyboardAccelerator value currKeyboardAccelerator = preferences.User.KeyboardAccelerator MsgBox "The current value for KeyboardAccelerator is " & currKeyboardAccelerator, vbInformation, "KeyboardAccelerator Example" ' Change the value for KeyboardAccelerator If currKeyboardAccelerator = acPreferenceClassic Then preferences.User.KeyboardAccelerator = acPreferenceCustom Else preferences.User.KeyboardAccelerator = acPreferenceClassic End If MsgBox "The new value for KeyboardAccelerator is " & preferences.User.KeyboardAccelerator, vbInformation, "KeyboardAccelerator Example" ' Reset KeyboardAccelerator to its original value preferences.User.KeyboardAccelerator = currKeyboardAccelerator MsgBox "The KeyboardAccelerator value is reset to " & preferences.User.KeyboardAccelerator, vbInformation, "KeyboardAccelerator Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_KeyboardAccelerator() ;; This example returns the current setting of ;; KeyboardAccelerator. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current KeyboardAccelerator value (setq currKeyboardAccelerator (vla-get-KeyboardAccelerator (vla-get-User preferences))) (alert (strcat "The current value for KeyboardAccelerator is " (if (= currKeyboardAccelerator acPreferenceClassic) "Classic" "Custom"))) ;; Change the value for KeyboardAccelerator (if (= currKeyboardAccelerator acPreferenceClassic) (vla-put-KeyboardAccelerator (vla-get-User preferences) acPreferenceCustom) (vla-put-KeyboardAccelerator (vla-get-User preferences) acPreferenceClassic) ) (alert (strcat "The new value for KeyboardAccelerator is " (if (= (vla-get-KeyboardAccelerator (vla-get-User preferences)) acPreferenceClassic) "Classic" "Custom"))) ;; Reset KeyboardAccelerator to its original value (vla-put-KeyboardAccelerator (vla-get-User preferences) currKeyboardAccelerator) (alert (strcat "The KeyboardAccelerator value is reset to " (if (= (vla-get-KeyboardAccelerator (vla-get-User preferences)) acPreferenceClassic) "Classic" "Custom"))) ) |
GMT+8, 2024-6-10 19:58
