确定给定块是否为外部参照块。 支持的平台:仅窗口 属性值只读:是的 类型:布尔
言论该物业与该物业合作。如果两个属性都是,则块是一个简单的块。如果属性是,则块是外部引用。如果属性为 ,则块包含与布局关联的所有几何图形。IsXRefIsLayoutFalseIsXRefTrueIsLayoutTrue 例子工 务 局: Sub Example_IsXRef() ' This example cycles through each Block object in a drawing ' and determines the style of each Block by accessing the ' IsLayout and IsXRef properties. A Block ' object is also added at runtime so the results are mixed and do not only ' come from the default Blocks. Dim circleObj As AcadCircle Dim centerPoint(0 To 2) As Double, InsertPoint(0 To 2) As Double Dim radius As Double Dim newBlock As AcadBlock, insertedBlock As AcadBlockReference Dim tempBlock As AcadBlock Dim msg As String ' Define the Circle object that will be inserted into the block centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0 InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0 radius = 0.5 ' Create a new block to hold the Circle object Set newBlock = ThisDrawing.Blocks.Add(centerPoint, "CBlock") ' Add the Circle object to the new block object Set circleObj = ThisDrawing.Blocks("CBlock").AddCircle(centerPoint, radius) ' Add the new block to model space Set insertedBlock = ThisDrawing.ModelSpace.InsertBlock(InsertPoint, "CBlock", 1, 1, 1, 0) ThisDrawing.Application.ZoomAll msg = vbCrLf & vbCrLf For Each tempBlock In ThisDrawing.Blocks If Not (tempBlock.IsLayout) And Not (tempBlock.IsXRef) Then ' Block is simple msg = msg & tempBlock.name & ": Simple" ElseIf tempBlock.IsXRef Then ' Block is an external reference msg = msg & tempBlock.name & ": External Reference" If tempBlock.IsLayout Then ' Block also contains layout geometry msg = msg & tempBlock.name & " and Contains Layout Geometry" End If ElseIf tempBlock.IsLayout Then ' Block contains layout geometry msg = msg & tempBlock.name & ": Contains Layout Geometry" End If msg = msg & vbCrLf ' Move to next line Next ' Display Block information for this drawing MsgBox "Blocks in this drawing have the following styles: " & msg End Sub Visual LISP: (vl-load-com) (defun c:Example_IsXref() ;; This example cycles through each Block object in a drawing ;; and determines whether style of each Block by accessing the ;; IsLayout and IsXRef properties. A Block ;; object is also added at runtime so the results are mixed and do not only ;; come from the default Blocks. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the Circle object that will be inserted into the block (setq centerPoint (vlax-3d-point 0 0 0) insertPoint (vlax-3d-point 1 1 0) radius 0.5) ;; Create a new block to hold the Circle object (setq newBlock (vla-Add (vla-get-Blocks doc) centerPoint "CBlock")) ;; Add the Circle object to the new block object (setq circleObj (vla-AddCircle (vla-Item (vla-get-Blocks doc) "CBlock") centerPoint radius)) ;; Add the new block to model space (setq modelSpace (vla-get-ModelSpace doc)) (setq insertedBlock (vla-InsertBlock modelSpace InsertPoint "CBlock" 1 1 1 0)) (vla-ZoomAll acadObj) (setq msg "") (vlax-for tempBlock (vla-get-Blocks doc) (cond ((and (= (vla-get-IsLayout tempBlock) :vlax-false) (= (vla-get-IsXRef tempBlock) :vlax-false)) ;; Block is simple (setq msg (strcat msg (vla-get-Name tempBlock) ": Simple")) ) ((= (vla-get-IsXRef tempBlock) :vlax-true) ;; Block is simple (setq msg (strcat msg (vla-get-Name tempBlock) ": External Reference")) (if (= (vla-get-IsLayout tempBlock) :vlax-true) ;; Block also contains layout geometry (setq msg (strcat msg (vla-get-Name tempBlock) " and Contains Layout Geometry")) ) ) ((= (vla-get-IsLayout tempBlock) :vlax-true) ;; Block is simple (setq msg (strcat msg (vla-get-Name tempBlock) ": Contains Layout Geometry")) ) ) (setq msg (strcat msg "\n")) ) ;; Display Block information for this drawing (alert (strcat "Blocks in this drawing have the following styles: " msg)) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-10 23:00
