指定数字证书的颁发者名称。 支持的平台:仅窗口 属性值只读:不 类型:字符串 数字证书的颁发者名称。 言论没有额外的评论。 例子工 务 局: Sub Example_Issuer() ' This example attaches a digital signature and accompanying data to a file, ' and saves the file. Dim sp As AcadSecurityParams Set sp = GetInterfaceObject("AutoCAD.SecurityParams." & Left(AcadApplication.Version, 2)) ' Attach a digital signature and timestamp it sp.Action = AcadSecurityParamsType.ACADSECURITYPARAMS_SIGN_DATA _ + AcadSecurityParamsType.ACADSECURITYPARAMS_ADD_TIMESTAMP ' Certificate details follow sp.Subject = "Thawte Freemail Member" sp.Issuer = "Personal Freemail RSA 2000.8.30" sp.SerialNumber = "073848" sp.Comment = "This is now signed" sp.TimeServer = "NIST(time.nist.gov)" ThisDrawing.SaveAs "C:\MyDrawing.dwg", , sp End Sub Visual LISP: (vl-load-com) (defun c:Example_Issuer() ;; This example attaches a digital signature and accompanying data to a file, ;; and saves the file. (setq acadObj (vlax-get-acad-object)) (setq sp (vlax-create-object (strcat "AutoCAD.SecurityParams." (substr (getvar "ACADVER") 1 2)))) (vla-put-Visible acadObj :vlax-true) ;; Attach a digital signature and timestamp it (vla-put-Action sp (+ ACADSECURITYPARAMS_SIGN_DATA ACADSECURITYPARAMS_ADD_TIMESTAMP)) ;; Certificate details follow (vla-put-Subject sp "Thawte Freemail Member") (vla-put-Issuer sp "Personal Freemail RSA 2000.8.30") (vla-put-SerialNumber sp "073848") (vla-put-Comment sp "This is now signed") (vla-put-TimeServer sp "NIST(time.nist.gov)") (setq doc (vla-get-ActiveDocument acadObj)) (vla-SaveAs doc "C:\\MyDrawing.dwg" acNative sp) (vlax-release-object sp) ) |
GMT+8, 2024-6-2 17:53
