指定图形文件中允许的浪费空间百分比。 支持的平台:仅窗口 属性值只读:不 类型:整数 有效范围为 0 到 100。 言论此属性的初始值为 50。 达到指定的百分比时,AutoCAD 将执行完全保存,而不是增量保存。完全节省,消除空间浪费。如果将此属性设置为 0,则每次保存都是完全保存。 尽管增量保存会增加绘图的大小,但不要设置非常低的值。为获得最佳性能,请将值设置为 50。如果内存成为问题,请将值设置为 25。如果将该值设置为 20 或更小,则性能会显著降低。值越低会降低程序的性能,因为 AutoCAD 执行耗时的完整保存的频率更高。 注意:此属性的值存储在 ISAVEPERCENT 系统变量中。
例子工 务 局: Sub Example_IncrementalSavePercent() ' This example returns the current setting of ' IncrementalSavePercent. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currIncrementalSavePercent As Integer Dim newIncrementalSavePercent As Integer Set preferences = ThisDrawing.Application.preferences ' Retrieve the current IncrementalSavePercent value currIncrementalSavePercent = preferences.OpenSave.IncrementalSavePercent MsgBox "The current value for IncrementalSavePercent is " & currIncrementalSavePercent, vbInformation, "IncrementalSavePercent Example" ' Change the value for IncrementalSavePercent newIncrementalSavePercent = 20 preferences.OpenSave.IncrementalSavePercent = newIncrementalSavePercent MsgBox "The new value for IncrementalSavePercent is " & newIncrementalSavePercent, vbInformation, "IncrementalSavePercent Example" ' Reset IncrementalSavePercent to its original value preferences.OpenSave.IncrementalSavePercent = currIncrementalSavePercent MsgBox "The IncrementalSavePercent value is reset to " & currIncrementalSavePercent, vbInformation, "IncrementalSavePercent Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_IncrementalSavePercent() ;; This example returns the current setting of ;; IncrementalSavePercent. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current IncrementalSavePercent value (setq currIncrementalSavePercent (vla-get-IncrementalSavePercent (vla-get-OpenSave preferences))) (alert (strcat "The current value for IncrementalSavePercent is " (itoa currIncrementalSavePercent))) ;; Change the value for IncrementalSavePercent (setq newIncrementalSavePercent 20) (vla-put-IncrementalSavePercent (vla-get-OpenSave preferences) newIncrementalSavePercent) (alert (strcat "The new value for IncrementalSavePercent is " (itoa (vla-get-IncrementalSavePercent (vla-get-OpenSave preferences))))) ;; Reset IncrementalSavePercent to its original value (vla-put-IncrementalSavePercent (vla-get-OpenSave preferences) currIncrementalSavePercent) (alert (strcat "The IncrementalSavePercent value is reset to " (itoa currIncrementalSavePercent))) ) |
GMT+8, 2024-6-10 22:18
