指定文本窗口中要保留在内存中的文本行数。 支持的平台:仅窗口 属性值只读:不 类型:整数 初始值为 400。 言论没有额外的评论。 例子工 务 局: Sub Example_HistoryLines() ' This example returns the current setting of ' HistoryLines. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currHistoryLines As Integer Set preferences = ThisDrawing.Application.preferences ' Retrieve the current HistoryLines value currHistoryLines = preferences.DISPLAY.HistoryLines MsgBox "The current value for HistoryLines is " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example" ' Change the value for HistoryLines preferences.DISPLAY.HistoryLines = 42 MsgBox "The new value for HistoryLines is " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example" ' Reset HistoryLines to its original value preferences.DISPLAY.HistoryLines = currHistoryLines MsgBox "The HistoryLines value is reset to " & preferences.DISPLAY.HistoryLines, vbInformation, "HistoryLines Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_HistoryLines() ;; This example returns the current setting of ;; HistoryLines. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current HistoryLines value (setq currHistoryLines (vla-get-HistoryLines (vla-get-Display preferences))) (alert (strcat "The current value for HistoryLines is " (itoa currHistoryLines))) ;; Change the value for HistoryLines (vla-put-HistoryLines (vla-get-Display preferences) 42) (alert (strcat "The new value for HistoryLines is " (itoa (vla-get-HistoryLines (vla-get-Display preferences))))) ;; Reset HistoryLines to its original value (vla-put-HistoryLines (vla-get-Display preferences) currHistoryLines) (alert (strcat "The HistoryLines value is reset to " (itoa (vla-get-HistoryLines (vla-get-Display preferences))))) ) |
GMT+8, 2024-6-10 16:52
