指定 AutoCAD 帮助文件的位置。 支持的平台:仅窗口 属性值只读:不 类型:字符串 AutoCAD 帮助文件的位置。 言论此属性指定 AutoCAD 帮助文件的驱动器、路径和文件名。 例子工 务 局: Sub Example_HelpFilePath() ' This example returns the current setting of ' HelpFilePath. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currHelpFilePath As String Dim newHelpFilePath As String Set preferences = ThisDrawing.Application.preferences ' Retrieve the current HelpFilePath value currHelpFilePath = preferences.Files.HelpFilePath MsgBox "The current value for HelpFilePath is " & currHelpFilePath, vbInformation, "HelpFilePath Example" ' Change the value for HelpFilePath newHelpFilePath = "C:/AutoCAD/Help" preferences.Files.HelpFilePath = newHelpFilePath MsgBox "The new value for HelpFilePath is " & newHelpFilePath, vbInformation, "HelpFilePath Example" ' Reset HelpFilePath to its original value preferences.Files.HelpFilePath = currHelpFilePath MsgBox "The HelpFilePath value is reset to " & currHelpFilePath, vbInformation, "HelpFilePath Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_HelpFilePath() ;; This example returns the current setting of ;; HelpFilePath. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current HelpFilePath value (setq currHelpFilePath (vla-get-HelpFilePath (vla-get-Files preferences))) (alert (strcat "The current value for HelpFilePath is " currHelpFilePath)) ;; Change the value for HelpFilePath (setq newHelpFilePath "C:/AutoCAD/Help") (vla-put-HelpFilePath (vla-get-Files preferences) newHelpFilePath) (alert (strcat "The new value for HelpFilePath is " newHelpFilePath)) ;; Reset HelpFilePath to its original value (vla-put-HelpFilePath (vla-get-Files preferences) currHelpFilePath) (alert (strcat "The HelpFilePath value is reset to " currHelpFilePath)) ) |
GMT+8, 2024-6-2 19:50
