指定是否禁止显示表的标题。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论没有额外的评论。 例子工 务 局: Sub Example_HeaderSuppressed() ' This example creates a TableStyle object and sets values for ' the style name and other attributes. Dim dictionaries As AcadDictionaries Set dictionaries = ThisDrawing.Database.dictionaries Dim dictObj As AcadDictionary Set dictObj = dictionaries.Item("acad_tablestyle") ' Create the custom TableStyle object in the dictionary Dim keyName As String Dim className As String Dim customObj As AcadTableStyle keyName = "NewStyle" className = "AcDbTableStyle" Set customObj = dictObj.AddObject(keyName, className) customObj.Name = "NewStyle" customObj.Description = "New Style for My Tables" customObj.FlowDirection = acTableBottomToTop customObj.HorzCellMargin = 0.22 customObj.BitFlags = 1 customObj.SetTextHeight AcRowType.acDataRow + AcRowType.acTitleRow, 1.3 customObj.SetTextStyle AcRowType.acDataRow + AcRowType.acTitleRow, "Standard" Dim col As AcadAcCmColor Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2)) col.SetRGB 12, 23, 45 customObj.SetBackgroundColor AcRowType.acDataRow + AcRowType.acTitleRow, col customObj.SetGridVisibility AcGridLineType.acHorzInside + AcGridLineType.acHorzTop _ , AcRowType.acDataRow + AcRowType.acTitleRow, True customObj.SetAlignment AcRowType.acDataRow + AcRowType.acTitleRow, acBottomRight col.SetRGB 244, 0, 0 customObj.SetGridColor 3, 1, col MsgBox "Table Style Name = " & customObj.Name & vbCrLf & _ "Style Description = " & customObj.Description & vbCrLf & _ "Flow Direction = " & customObj.FlowDirection & vbCrLf & _ "Horzontal Cell Margin = " & customObj.HorzCellMargin & vbCrLf & _ "Bit Flags = " & customObj.BitFlags & vbCrLf & _ "Title Row Text Height = " & customObj.GetTextHeight(acTitleRow) & vbCrLf & _ "Title Row Text Style = " & customObj.GetTextStyle(acTitleRow) & vbCrLf & _ "Grid Visibility for HorizontalBottom TitleRow = " & customObj.GetGridVisibility(acHorzBottom, acTitleRow) & vbCrLf & _ "Title Row Alignment = " & customObj.GetAlignment(acTitleRow) & vbCrLf & _ "Header Suppression = " & customObj.HeaderSuppressed End Sub Visual LISP: (vl-load-com) (defun c:Example_HeaderSuppressed() ;; This example creates a TableStyle object and sets values for ;; the style name and other attributes. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq dictionaries (vla-get-Dictionaries doc)) (setq dictObj (vla-Item dictionaries "acad_tablestyle")) ;; Create the custom TableStyle object in the dictionary (setq keyName "NewStyle" className "AcDbTableStyle") (setq customObj (vla-AddObject dictObj keyName className)) (vla-put-Name customObj "NewStyle") (vla-put-Description customObj "New Style for My Tables") (vla-put-FlowDirection customObj acTableBottomToTop) (vla-put-HorzCellMargin customObj 0.22) (vla-put-BitFlags customObj 1) (vla-SetTextHeight customObj (+ acDataRow acTitleRow) 1.3) (vla-SetTextStyle customObj (+ acDataRow acTitleRow) "Standard") (setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2)))) (vla-SetRGB col 12 23 45) (vla-SetBackgroundColor customObj (+ acDataRow acTitleRow) col) (vla-SetGridVisibility customObj (+ acHorzInside acHorzTop) (+ acDataRow acTitleRow) :vlax-true) (vla-SetAlignment customObj (+ acDataRow acTitleRow) acBottomRight) (vla-SetRGB col 244 0 0) (vla-SetGridColor customObj (+ acHorzTop acHorzInside) acDataRow col) (alert (strcat "Table Style Name = " (vla-get-Name customObj) "\nStyle Description = " (vla-get-Description customObj) "\nFlow Direction = " (itoa (vla-get-FlowDirection customObj)) "\nHorzontal Cell Margin = " (rtos (vla-get-HorzCellMargin customObj) 2) "\nBit Flags = " (itoa (vla-get-BitFlags customObj)) "\nTitle Row Text Height = " (rtos (vla-GetTextHeight customObj acTitleRow) 2) "\nTitle Row Text Style = " (vla-GetTextStyle customObj acTitleRow) "\nGrid Visibility for HorizontalBottom TitleRow = " (if (= (vla-GetGridVisibility customObj acHorzBottom acTitleRow) :vlax-true) "True" "False") "\nTitle Row Alignment = " (itoa (vla-GetAlignment customObj acTitleRow)) "\nHeader Suppression = " (if (= (vla-get-HeaderSuppressed customObj) :vlax-true) "True" "False") "\nTitle Suppression = " (if (= (vla-get-TitleSuppressed customObj) :vlax-true) "True" "False") ) ) (vlax-release-object col) ) |
GMT+8, 2024-6-2 19:34
