指定块中是否具有任何属性。 支持的平台:仅窗口 属性值只读:是的 类型:布尔
言论如果块参照包含任何可编辑或常量(不可编辑)属性,则此属性为。是如果没有属性。TrueFalse 要返回与块关联的对象数组,请使用该方法。AttributeGetAttributes 例子工 务 局: Sub Example_HasAttributes() ' This example first creates a block without attributes. ' It then inserts the block and checks whether it has attributes. ' It then adds attributes to the block and inserts it again. ' Then it checks the new block reference for attributes. ' Create the block Dim blockObj As AcadBlock Dim insertionPnt(0 To 2) As Double insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0# Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock") ' Add a circle to the block Dim circleObj As AcadCircle Dim center(0 To 2) As Double Dim radius As Double center(0) = 0: center(1) = 0: center(2) = 0 radius = 1 Set circleObj = blockObj.AddCircle(center, radius) ' Insert the block Dim blockRefObj As AcadBlockReference insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0 Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0) ThisDrawing.Application.ZoomAll MsgBox "This block reference " & IIf(blockRefObj.HasAttributes, "has attributes.", "does not have attributes."), , "Has Attributes Example" ' Add attributes to the block definition. ' Define the attribute definition. Dim attributeObj As AcadAttribute Dim height As Double Dim mode As Long Dim prompt As String Dim insertionPoint(0 To 2) As Double Dim tag As String Dim value As String height = 1# mode = acAttributeModeVerify prompt = "Attribute Prompt" insertionPoint(0) = 1#: insertionPoint(1) = 1#: insertionPoint(2) = 0 tag = "Attribute_Tag" value = "Attribute Value" ' Create the attribute definition Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value) ' Insert the block again Dim blockRefObj2 As AcadBlockReference insertionPnt(0) = 3#: insertionPnt(1) = 3#: insertionPnt(2) = 0 Set blockRefObj2 = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0) ZoomAll MsgBox "The first block reference " & IIf(blockRefObj.HasAttributes, "has attributes.", "does not have attributes.") & vbCrLf & _ "The second block reference " & IIf(blockRefObj2.HasAttributes, "has attributes.", "does not have attributes."), , "Has Attributes Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_HasAttributes() ;; This example first creates a block without attributes. ;; It then inserts the block and checks whether it has attributes. ;; It then adds attributes to the block and inserts it again. ;; Then it checks the new block reference for attributes. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create the block (setq insertionPnt (vlax-3d-point 0 0 0)) (setq blockObj (vla-Add (vla-get-Blocks doc) insertionPnt "CircleBlock")) ;; Add a circle to the block (setq center (vlax-3d-point 0 0 0)) (setq radius 1) (setq circleObj (vla-AddCircle blockObj center radius)) ;; Insert the block (setq insertionPnt (vlax-3d-point 2 2 0)) (setq modelSpace (vla-get-ModelSpace doc)) (setq blockRefObj (vla-InsertBlock modelSpace insertionPnt "CircleBlock" 1 1 1 0)) (vla-ZoomAll acadObj) (alert (strcat "This block reference " (if (= (vla-get-HasAttributes blockRefObj) :vlax-true) "has attributes." "does not have attributes."))) ;; Add attributes to the block definition. ;; Define the attribute definition. (setq insertionPoint (vlax-3d-point 1 1 0) attHeight 1 attMode acAttributeModeVerify attPrompt "Attribute Prompt" attTag "Attribute_Tag" attValue "Attribute Value") ;; Create the attribute definition (setq attributeObj (vla-AddAttribute blockObj attHeight attMode attPrompt insertionPoint attTag attValue)) ;; Insert the block again (setq insertionPnt (vlax-3d-point 3 3 0)) (setq blockRefObj2 (vla-InsertBlock modelSpace insertionPnt "CircleBlock" 1 1 1 0)) (vla-ZoomAll acadObj) (alert (strcat "The first block reference " (if (= (vla-get-HasAttributes blockRefObj) :vlax-true) "has attributes." "does not have attributes.") "\nThe second block reference " (if (= (vla-get-HasAttributes blockRefObj2) :vlax-true) "has attributes." "does not have attributes."))) ) |
GMT+8, 2024-6-11 04:23
