获取文档的组集合。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_Groups() ' This example finds the current Groups collection and ' adds a new group to that collection. Dim groupColl As AcadGroups Set groupColl = ThisDrawing.Groups ' Create a dimension style named "TEST" in current drawing Dim testGroup As AcadGroup Set testGroup = groupColl.Add("TEST") MsgBox "A new group called " & testGroup.name & " has been added to the Groups collection.", vbInformation, "Groups Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_Groups() ;; This example finds the current Groups collection and ;; adds a new group to that collection. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq groupColl (vla-get-Groups doc)) ;; Create a dimension style named "TEST" in current drawing (setq testGroup (vla-Add groupColl "TEST")) (alert (strcat "A new group called " (vla-get-Name testGroup) " has been added to the Groups collection.")) ) |
GMT+8, 2024-6-11 01:00
