指定夹点的大小。 支持的平台:仅窗口 属性值只读:不 类型:朗特 为显示夹点而绘制的框的大小(以像素为单位)。此属性的实际范围是 1 到 20,尽管 1 到 255 之间的任何值都是有效的。 言论此属性的初始值为 3。 注意:此属性的值存储在 GRIPSIZE 系统变量中。
例子工 务 局: Sub Example_GripSize() ' This example reads and modifies the preference value that controls ' the size of grips. When finished, this example resets the ' preference value back to its original value. Dim ACADPref As AcadPreferencesSelection Dim originalValue As Variant, newValue As Variant ' Get the selection preferences object Set ACADPref = ThisDrawing.Application.preferences.Selection ' Read and display the original value originalValue = ACADPref.GripSize MsgBox "The GripSize preference is set to: " & originalValue ' Modify the GripSize preference by setting it to 5 ACADPref.GripSize = 5 newValue = ACADPref.GripSize MsgBox "The GripSize preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.GripSize = originalValue MsgBox "The GripSize preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_GripSize() ;; This example reads and modifies the preference value that controls ;; the size of grips. When finished, this example resets the ;; preference value back to its original value. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get the selection preferences object (setq ACADPref (vla-get-Selection (vla-get-preferences acadObj))) ;; Read and display the original value (setq originalValue (vla-get-GripSize ACADPref)) (alert (strcat "The GripSize preference is set to: " (itoa originalValue))) ;; Modify the GripSize preference by setting it to 7 (vla-put-GripSize ACADPref 7) (setq newValue (vla-get-GripSize ACADPref)) (alert (strcat "The GripSize preference has been set to: " (itoa newValue))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-GripSize ACADPref originalValue) (alert (strcat "The GripSize preference was reset back to: " (itoa originalValue))) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 03:26
