获取应用程序或文档的名称,包括路径。 支持的平台:仅窗口 属性值只读:是的 类型:字符串 应用程序或文档的名称和路径。 言论没有额外的评论。 例子工 务 局: Sub Example_FullName() ' This example uses the FullName property to find ' the full name of the current drawing, and of ' the application. ' Find the full name of current drawing file including path. ' (If the drawing has not been saved, this name will be blank.) Dim docName As String docName = ThisDrawing.FullName MsgBox "The full name of the current drawing is " & docName, , "FullName Example" ' Find the full name of application Dim appName As String appName = ThisDrawing.Application.FullName MsgBox "The full name of the current application is " & appName, , "FullName Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_FullName() ;; This example uses the FullName property to find ;; the full name of the current drawing, and of ;; the application. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Find the full name of current drawing file including path. ;; (If the drawing has not been saved, this name will be blank.) (setq docName (vla-get-FullName doc)) (alert (strcat "The full name of the current drawing is " docName)) ;; Find the full name of application (setq appName (vla-get-FullName acadObj)) (alert (strcat "The full name of the current application is " appName)) ) |
GMT+8, 2024-6-10 20:03
