指定定义 AutoCAD 应如何转换未找到的字体的文件的位置。 支持的平台:仅窗口 属性值只读:不 类型:字符串 字体映射文件的驱动器、路径和文件名。 言论没有额外的评论。 例子工 务 局: Sub Example_FontFileMap() ' This example returns the current setting of ' FontFileMap. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currFontFileMap As String Dim newFontFileMap As String Set preferences = ThisDrawing.Application.preferences ' Retrieve the current FontFileMap value currFontFileMap = preferences.Files.FontFileMap MsgBox "The current value for FontFileMap is " & currFontFileMap, vbInformation, "FontFileMap Example" ' Change the value for FontFileMap newFontFileMap = "TestFontFileMap.fmp" preferences.Files.FontFileMap = newFontFileMap MsgBox "The new value for FontFileMap is " & newFontFileMap, vbInformation, "FontFileMap Example" ' Reset FontFileMap to its original value preferences.Files.FontFileMap = currFontFileMap MsgBox "The FontFileMap value is reset to " & currFontFileMap, vbInformation, "FontFileMap Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_FontFileMap() ;; This example returns the current setting of ;; FontFileMap. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current FontFileMap value (setq currFontFileMap (vla-get-FontFileMap (vla-get-Files preferences))) (alert (strcat "The current value for FontFileMap is " currFontFileMap)) ;; Change the value for FontFileMap ;; The file being specified must exist or an error will be generated (setq newFontFileMap "C:\\AutoCAD\\TestFontFileMap.fmp") (vla-put-FontFileMap (vla-get-Files preferences) newFontFileMap) (alert (strcat "The new value for FontFileMap is " newFontFileMap)) ;; Reset FontFileMap to its original value (vla-put-FontFileMap (vla-get-Files preferences) currFontFileMap) (alert (strcat "The FontFileMap value is reset to " currFontFileMap)) ) |
GMT+8, 2024-6-10 23:27
