指定主字体文件名和路径。 支持的平台:仅窗口 属性值只读:不 类型:字符串 主字体文件路径。 言论若要指定亚洲语言字体文件,请使用属性。BigFontFile 字体定义构成每个字符集的文本字符的形状。 注意:设置此属性后,必须调用该方法以查看对文本的更改。Regen
例子工 务 局: Sub Example_FontFile() ' This example returns the current setting of ' the FontFile property. It then changes the value, and ' finally resets the value back to the original setting. Dim textStyle1 As AcadTextStyle Dim currFontFile As String Dim newFontFile As String Set textStyle1 = ThisDrawing.ActiveTextStyle ' Retrieve the current FontFile value currFontFile = textStyle1.fontFile MsgBox "The current value for FontFile is " & currFontFile, vbInformation, "FontFile Example" ' Change the value for FontFile newFontFile = "C:/AutoCAD/Fonts/italic.shx" textStyle1.fontFile = newFontFile MsgBox "The new value for FontFile is " & textStyle1.fontFile, vbInformation, "FontFile Example" ' Reset font file textStyle1.fontFile = currFontFile MsgBox "The value for FontFile has been reset to " & textStyle1.fontFile, vbInformation, "FontFile Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_FontFile() ;; This example returns the current setting of ;; the FontFile property. It then changes the value, and ;; finally resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq textStyle1 (vla-get-ActiveTextStyle doc)) ;; Retrieve the current FontFile value (setq currFontFile (vla-get-FontFile textStyle1)) (alert (strcat "The current value for FontFile is " currFontFile)) ;; Change the value for FontFile (setq newFontFile (findfile "./Fonts/italic.shx")) (vla-put-FontFile textStyle1 newFontFile) (alert (strcat "The new value for FontFile is " (vla-get-FontFile textStyle1))) ;; Reset font file (if (= (findfile currFontFile) nil) (setq currFontFile (findfile (strcat (getenv "WinDir") "\\Fonts\\" currFontFile))) ) (vla-put-FontFile textStyle1 (findfile currFontFile)) (alert (strcat "The value for FontFile has been reset to " (vla-get-FontFile textStyle1))) ) |
GMT+8, 2024-6-11 00:58
