获取首选项文件对象。 支持的平台:仅窗口 言论该对象保存存储在注册表中的“选项”对话框中“文件”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesFilesDatabasePreferences 例子工 务 局: Sub Example_Files() ' This example obtains a reference to the Files Preferences object ' from the Application Preferences object, and reads one of the File ' preferences Dim ACADPref As AcadPreferencesFiles ' Obtain a reference to the Files Preferences object Set ACADPref = ThisDrawing.Application.preferences.Files MsgBox "We now have access to the properties and methods of the Files Preferences object!" MsgBox "The File preference AutoSavePath is set to: " & ACADPref.AutoSavePath End Sub Visual LISP: (vl-load-com) (defun c:Example_Files() ;; This example obtains a reference to the Files Preferences object ;; from the Application Preferences object, and reads one of the File ;; preferences (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Obtain a reference to the Files Preferences object (setq ACADPref (vla-get-Files preferences)) (alert "We now have access to the properties and methods of the Files Preferences object!") (alert (strcat "The File preference AutoSavePath is set to: " (vla-get-AutoSavePath ACADPref))) ) |
GMT+8, 2024-6-10 20:20
