指定第二条延伸线的起点。 支持的平台:仅窗口 属性值只读:不 类型:变体(双精度的三元素数组) 表示第二条延伸线起点的 3D 坐标。 言论与属性等于方法中的与参数。延伸线最初是从与位置到尺寸线的交点绘制的。AutoCAD 将尺寸线绘制为延伸线之间的弧。ExtLine1StartPointExtLine2StartPointFirstEndPointSecondEndPointAddDimAngularFirstEndPointSecondEndPoint 例子工 务 局: Sub Example_ExtLine2StartPoint() ' This example creates an angular dimension. It then changes ' the location of the ExtLine2StartPoint. Dim dimObj As AcadDimAngular Dim angVert(0 To 2) As Double Dim FirstPoint(0 To 2) As Double Dim SecondPoint(0 To 2) As Double Dim TextPoint(0 To 2) As Double ' Define the dimension angVert(0) = 0#: angVert(1) = 5#: angVert(2) = 0# FirstPoint(0) = 1#: FirstPoint(1) = 7#: FirstPoint(2) = 0# SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0# TextPoint(0) = 3#: TextPoint(1) = 5#: TextPoint(2) = 0# ' Create the angular dimension in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint) ZoomAll MsgBox "The current value of ExtLine2StartPoint is " & dimObj.ExtLine2StartPoint(0) & ", " & dimObj.ExtLine2StartPoint(1) & ", " & dimObj.ExtLine2StartPoint(2), vbInformation, "ExtLine2StartPoint Example" ' Change the start point of the second extension line FirstPoint(0) = 1: FirstPoint(1) = 4: FirstPoint(2) = 0 dimObj.ExtLine2StartPoint = FirstPoint dimObj.Update ' Return the start point of the second extension line ' Note that the return value is a Variant Dim retPnt As Variant retPnt = dimObj.ExtLine2StartPoint MsgBox "The new value of ExtLine2StartPoint is " & dimObj.ExtLine2StartPoint(0) & ", " & dimObj.ExtLine2StartPoint(1) & ", " & dimObj.ExtLine2StartPoint(2), vbInformation, "ExtLine2StartPoint Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ExtLine2StartPoint() ;; This example creates an angular dimension. It then changes ;; the location of the ExtLine2StartPoint. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq AngleVertex (vlax-3d-point 0 5 0) FirstPoint (vlax-3d-point 1 7 0) SecondPoint (vlax-3d-point 1 3 0) TextPoint (vlax-3d-point 3 5 0)) ;; Create the angular dimension in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint)) (vla-ZoomAll acadObj) (setq extLineStartPoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine2StartPoint dimObj)))) (alert (strcat "The current value of ExtLine2StartPoint is " (rtos (nth 0 extLineStartPoint) 2) ", " (rtos (nth 1 extLineStartPoint) 2) ", " (rtos (nth 2 extLineStartPoint) 2))) ;; Change the start point of the second extension line (setq FirstPoint (vlax-3d-point 1 4 0)) (vla-put-ExtLine2StartPoint dimObj FirstPoint) (vla-Update dimObj) ;; Return the start point of the second extension line ;; Note that the return value is a Variant (setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine2StartPoint dimObj)))) (alert (strcat "The new value of ExtLine2StartPoint is " (rtos (nth 0 retPnt) 2) ", " (rtos (nth 1 retPnt) 2) ", " (rtos (nth 2 retPnt) 2))) ) |
GMT+8, 2024-6-11 00:25
