指定第一条延伸线的起点。 支持的平台:仅窗口 属性值只读:不 类型:变体(双精度的三元素数组) 表示第一条延伸线起点的 3D 坐标。 言论与属性等于方法中的与参数。延伸线最初是从与位置到尺寸线的交点绘制的。AutoCAD 将尺寸线绘制为延伸线之间的弧。ExtLine1StartPointExtLine2StartPointFirstEndPointSecondEndPointAddDimAngularFirstEndPointSecondEndPoint 例子工 务 局: Sub Example_ExtLine1StartPoint() ' This example creates an angular dimension. It then changes ' the location of the ExtLine1StartPoint. Dim dimObj As AcadDimAngular Dim angVert(0 To 2) As Double Dim FirstPoint(0 To 2) As Double Dim SecondPoint(0 To 2) As Double Dim TextPoint(0 To 2) As Double ' Define the dimension angVert(0) = 0#: angVert(1) = 5#: angVert(2) = 0# FirstPoint(0) = 1#: FirstPoint(1) = 7#: FirstPoint(2) = 0# SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0# TextPoint(0) = 3#: TextPoint(1) = 5#: TextPoint(2) = 0# ' Create the angular dimension in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint) ZoomAll MsgBox "The current value of ExtLine1StartPoint is " & dimObj.ExtLine1StartPoint(0) & ", " & dimObj.ExtLine1StartPoint(1) & ", " & dimObj.ExtLine1StartPoint(2), vbInformation, "ExtLine1StartPoint Example" ' Change the start point of the first extension line FirstPoint(0) = 0: FirstPoint(1) = 3: FirstPoint(2) = 0 dimObj.ExtLine1StartPoint = FirstPoint dimObj.Update ' Return the start point of the first extension line ' Note that the return value is a Variant Dim retPnt As Variant retPnt = dimObj.ExtLine1StartPoint MsgBox "The new value of ExtLine1StartPoint is " & dimObj.ExtLine1StartPoint(0) & ", " & dimObj.ExtLine1StartPoint(1) & ", " & dimObj.ExtLine1StartPoint(2), vbInformation, "ExtLine1StartPoint Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ExtLine1StartPoint() ;; This example creates an angular dimension. It then changes ;; the location of the ExtLine1StartPoint. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq AngleVertex (vlax-3d-point 0 5 0) FirstPoint (vlax-3d-point 1 7 0) SecondPoint (vlax-3d-point 1 3 0) TextPoint (vlax-3d-point 3 5 0)) ;; Create the angular dimension in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint)) (vla-ZoomAll acadObj) (setq extLineStartPoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1StartPoint dimObj)))) (alert (strcat "The current value of ExtLine1StartPoint is " (rtos (nth 0 extLineStartPoint) 2) ", " (rtos (nth 1 extLineStartPoint) 2) ", " (rtos (nth 2 extLineStartPoint) 2))) ;; Change the start point of the first extension line (setq FirstPoint (vlax-3d-point 0 3 0)) (vla-put-ExtLine1StartPoint dimObj FirstPoint) (vla-Update dimObj) ;; Return the start point of the first extension line ;; Note that the return value is a Variant (setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1StartPoint dimObj)))) (alert (strcat "The new value of ExtLine1StartPoint is " (rtos (nth 0 retPnt) 2) ", " (rtos (nth 1 retPnt) 2) ", " (rtos (nth 2 retPnt) 2))) ) |
GMT+8, 2024-6-11 05:05
