指定扩展线 1 的原点。 支持的平台:仅窗口 属性值只读:不 类型:变体(双精度的三元素数组) 表示第一条延伸线原点的 3D 坐标。 言论对齐尺寸的尺寸线将与连接延伸线 1 和 2 原点的线平行。 要标注尺寸的线 创建的维度 例子工 务 局: Sub Example_ExtLine1Point() ' This example creates an aligned dimension and then changes the ' ExtLine1Point property for that dimension. Dim dimObj As AcadDimAligned Dim point1(0 To 2) As Double Dim point2(0 To 2) As Double Dim location(0 To 2) As Double ' Define the dimension point1(0) = 5#: point1(1) = 5#: point1(2) = 0# point2(0) = 10#: point2(1) = 5#: point2(2) = 0# location(0) = 5#: location(1) = 7#: location(2) = 0# ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location) ZoomAll MsgBox "The current value for ExtLine1Point is " & dimObj.ExtLine1Point(0) & ", " & dimObj.ExtLine1Point(1) & ", " & dimObj.ExtLine1Point(2), vbInformation, "ExtLine1Point Example" ' Change the endpoint of the first extension line point1(0) = 2: point1(1) = 5: point1(2) = 0 dimObj.ExtLine1Point = point1 dimObj.Update ' Return the endpoint of the first extension line ' Note that the return value is a Variant Dim retPnt As Variant retPnt = dimObj.ExtLine1Point MsgBox "The new value for ExtLine1Point is " & dimObj.ExtLine1Point(0) & ", " & dimObj.ExtLine1Point(1) & ", " & dimObj.ExtLine1Point(2), vbInformation, "ExtLine1Point Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ExtLine1Point() ;; This example creates an aligned dimension and then changes the ;; ExtLine1Point property for that dimension. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 5 5 0) point2 (vlax-3d-point 10 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) (vla-ZoomAll acadObj) (setq extLinePoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1Point dimObj)))) (alert (strcat "The current value for ExtLine1Point is " (rtos (nth 0 extLinePoint) 2) ", " (rtos (nth 1 extLinePoint) 2) ", " (rtos (nth 2 extLinePoint) 2))) ;; Change the endpoint of the first extension line (setq point1 (vlax-3d-point 2 5 0)) (vla-put-ExtLine1Point dimObj point1) (vla-Update dimObj) ;; Return the endpoint of the first extension line ;; Note that the return value is a Variant (setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1Point dimObj)))) (alert (strcat "The new value for ExtLine1Point is " (rtos (nth 0 retPnt) 2) ", " (rtos (nth 1 retPnt) 2) ", " (rtos (nth 2 retPnt) 2))) ) |
GMT+8, 2024-6-10 20:17
