指定延长线超出尺寸线的距离。 支持的平台:仅窗口 属性值只读:不 类型:双 一个正实数,指定将延长线延伸到尺寸线之外的距离。 言论此属性的初始值为 0.1800。 注意:此属性将覆盖给定维度的 DIMEXE 系统变量的值。
例子工 务 局: Sub Example_ExtensionLineExtend() ' This example creates a Dim3PointAngular object in model space ' and changes the length of the extension line to extend 1.5 units past ' the dimension using the ExtensionLineExtend property Dim DimPointAngularObj As AcadDim3PointAngular Dim AngleVertex(0 To 2) As Double Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double Dim TextPoint(0 To 2) As Double ' Define the new Dim3PointAngular object AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0 FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0 SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0 TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0 ' Create the new Dim3PointAngular object in model space Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint) ThisDrawing.Application.ZoomAll ' Read and display current extension line extend length MsgBox "The extension line currently extends " & DimPointAngularObj.ExtensionLineExtend & " units past the dimension" ' Change the extension line extend length to extend 1.5 ' units past the dimension DimPointAngularObj.ExtensionLineExtend = 1.5 ThisDrawing.Regen acAllViewports ' Read and display current extension line extend length MsgBox "The extension line now extends " & DimPointAngularObj.ExtensionLineExtend & " units past the dimension" End Sub Visual LISP: (vl-load-com) (defun c:Example_ExtensionLineExtend() ;; This example creates a Dim3PointAngular object in model space ;; and changes the length of the extension line to extend 1.5 units past ;; the dimension using the ExtensionLineExtend property (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the new Dim3PointAngular object (setq AngleVertex (vlax-3d-point 0 0 0) FirstPoint (vlax-3d-point 2 2 0) SecondPoint (vlax-3d-point 1 4 0) TextPoint (vlax-3d-point 6 6 0)) ;; Create the new Dim3PointAngular object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint)) (vla-ZoomAll acadObj) ;; Read and display current extension line extend length (alert (strcat "The extension line currently extends " (rtos (vla-get-ExtensionLineExtend DimPointAngularObj) 2) " units past the dimension")) ;; Change the extension line extend length to extend 1.5 ;; units past the dimension (vla-put-ExtensionLineExtend DimPointAngularObj 1.5) (vla-Regen doc acAllViewports) ;; Read and display current extension line extend length (alert (strcat "The extension line now extends " (rtos (vla-get-ExtensionLineExtend DimPointAngularObj) 2) " units past the dimension")) ) |
GMT+8, 2024-6-2 17:32
