指定真彩色的颜色值。 支持的平台:仅窗口 属性值只读:不 类型:长 真彩色的颜色值。 言论此属性指定颜色的 32 位部分。AcCmEntityColor 例子工 务 局: Sub Example_EntityColor() Dim color As AcadAcCmColor Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2)) Dim y As Long y = MakeLong(MakeWord(194, 122), MakeWord(133, 144)) color.EntityColor = y Dim line As AcadLine Set line = CreateLine line.TrueColor = color Dim retcolor As AcadAcCmColor Set retcolor = line.TrueColor Dim x As Long x = retcolor.EntityColor Dim BreakLong(3) As Byte BreakLong(0) = x And &HFF& BreakLong(1) = (x And &HFF00&) \ &H100& BreakLong(2) = (x And &HFF0000) \ &H10000 BreakLong(3) = (x And &H7F000000) \ &H1000000 If x < 0 Then BreakLong(3) = BreakLong(3) Or &H80 MsgBox "ColorMethod = " & BreakLong(3) & vbCrLf & _ "Red = " & BreakLong(2) & vbCrLf & _ "Green = " & BreakLong(1) & vbCrLf & _ "Blue = " & BreakLong(0) End Sub Private Function CreateLine() As AcadLine Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double Dim endPoint(0 To 2) As Double startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0# endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0# Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) Set CreateLine = lineObj ZoomAll End Function Private Function MakeLong(WordHi As Variant, WordLo As Integer) As Long ' High word is coerced to a variant on the call, to allow ' it to overflow the limits of multiplication, which shifts ' it left. MakeLong = (WordHi * &H10000) + (WordLo And &HFFFF&) End Function Private Function MakeWord(ByteHi As Byte, ByteLo As Byte) As Integer ' If the high byte would push the final result out of the ' signed integer range, it must be slid back. If ByteHi > &H7F Then MakeWord = ((ByteHi * &H100&) + ByteLo) - &H10000 Else MakeWord = (ByteHi * &H100&) + ByteLo End If End Function Visual LISP: (vl-load-com) (defun c:Example_EntityColor() (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2)))) (setq y (MakeLong (MakeWord 194 122) (MakeWord 133 144))) (vla-put-EntityColor color y) (setq modelSpace (vla-get-ModelSpace doc)) (setq line (CreateLine)) (vla-put-TrueColor line color) (setq retcolor (vla-get-TrueColor line)) (setq x (vla-get-EntityColor retcolor)) (setq BreakLong (vlax-make-safearray vlax-vbDouble '(0 . 3))) (vlax-safearray-put-element BreakLong 0 (logand x 255)) (vlax-safearray-put-element BreakLong 1 (/ (logand x 65280) 256)) (vlax-safearray-put-element BreakLong 2 (/ (logand x 16711680) 65536)) (vlax-safearray-put-element BreakLong 3 (/ (logand x 2130706432) 16777216)) (if (< x 0) (vlax-safearray-put-element BreakLong 3 (logior (fix (vlax-safearray-get-element BreakLong 3)) 128)) ) (alert (strcat "ColorMethod = " (itoa (fix (vlax-safearray-get-element BreakLong 3))) "\n" "Red = " (itoa (fix (vlax-safearray-get-element BreakLong 2))) "\n" "Green = " (itoa (fix (vlax-safearray-get-element BreakLong 1))) "\n" "Blue = " (itoa (fix (vlax-safearray-get-element BreakLong 0))))) (vlax-release-object color) ) (defun CreateLine() (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq startPoint (vlax-3d-point 1 1 0) endPoint (vlax-3d-point 5 5 0)) (setq modelSpace (vla-get-ModelSpace doc)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) (vla-ZoomAll acadObj) lineObj ) (defun MakeLong (WordHi WordLo) ;; High word is coerced to a variant on the call, to allow ;; it to overflow the limits of multiplication, which shifts ;; it left. (+ (* WordHi 65536) (logand WordLo 65535)) ) (defun MakeWord(ByteHi ByteLo) ;; If the high byte would push the final result out of the ;; signed integer range, it must be slid back. (if (> ByteHi 127) (- (+ (* ByteHi 256) ByteLo) 65536) (+ (* ByteHi 256) ByteLo) ) ) |
GMT+8, 2024-6-2 20:02
