指定图纸空间中的提升设置。 支持的平台:仅窗口 属性值只读:不 类型:双 图纸空间的高程。 言论当前高程是Z值,每当需要 3D 点但仅提供X和Y值时都会使用该值。当前高程在模型空间和图纸空间中分别维护。 例子工 务 局: Sub Example_ElevationPaperSpace() ' This example changes the paper space elevation of the current drawing ' and then resets it to the original value. Dim currElevation As Double currElevation = ThisDrawing.ElevationPaperSpace MsgBox "The current paper space elevation is " & ThisDrawing.ElevationPaperSpace, vbInformation, "ElevationpaperSpace Example" ' Change the elevation ThisDrawing.ElevationPaperSpace = currElevation + 2 MsgBox "The new paper space elevation is " & ThisDrawing.ElevationPaperSpace, vbInformation, "ElevationpaperSpace Example" ' Reset the elevation to its original value ThisDrawing.ElevationPaperSpace = currElevation MsgBox "The paper space elevation is reset to " & ThisDrawing.ElevationPaperSpace, vbInformation, "ElevationPaperSpace Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_ElevationPaperSpace() ;; This example changes the paper space elevation of the current drawing ;; and then resets it to the original value. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq currElevation (vla-get-ElevationPaperSpace doc)) (alert (strcat "The current paper space elevation is " (rtos currElevation 2))) ;; Change the elevation (vla-put-ElevationPaperSpace doc (+ currElevation 2)) (alert (strcat "The new paper space elevation is " (rtos (vla-get-ElevationPaperSpace doc) 2))) ;; Reset the elevation to its original value (vla-put-ElevationPaperSpace doc currElevation) (alert (strcat "The paper space elevation is reset to " (rtos (vla-get-ElevationPaperSpace doc) 2))) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 01:23
