狗腿的长度。 支持的平台:仅窗口 属性值只读:不 类型:双 指定着陆距离。 言论没有额外的评论。 例子工 务 局: Sub Example_DogLeg() Dim oML As AcadMLeader Dim points(0 To 14) As Double ' Define the leader points points(0) = 1: points(1) = 1: points(2) = 0 points(3) = 1: points(4) = 2: points(5) = 0 points(6) = 2: points(7) = 2: points(8) = 0 points(9) = 3: points(10) = 2: points(11) = 0 points(12) = 4: points(13) = 4: points(14) = 0 Dim i As Long Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i) oML.DogLegged = True oML.DoglegLength = 1.3 MsgBox "The dog-leg length is " & oML.DoglegLength ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_DogLeg() (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the leader points (setq points (vlax-make-safearray vlax-vbDouble '(0 . 14))) (vlax-safearray-fill points '(1 1 0 1 2 0 2 2 0 3 2 0 4 4 0 ) ) (setq i 0) (setq modelSpace (vla-get-ModelSpace doc)) (setq oML (vla-AddMLeader modelSpace points i)) (vla-put-DogLegged oML :vlax-true) (vla-put-DoglegLength oML 1.3) (alert (strcat "The dog-leg length is " (rtos (vla-get-DoglegLength oML) 2))) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-2 20:12
