指定尺寸线的线宽。 支持的平台:仅窗口 属性值只读:不 类型:枚举acLineWeight
言论此属性的初始值为。acLnWtByBlock 线宽设置仅在属性设置为 时才可见。LineweightDisplayTrue 例子工 务 局: Sub Example_DimensionLineWeight() ' This example creates a Dim3PointAngular object in model space ' and changes the dimension lineweight to a thicker value ' using the DimensionLineWeight property Dim DimPointAngularObj As AcadDim3PointAngular Dim AngleVertex(0 To 2) As Double Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double Dim TextPoint(0 To 2) As Double Dim oldLWSetting As Boolean Dim CurrentSetting As String ' Turn on lineweight display so the changes can be seen oldLWSetting = ThisDrawing.preferences.LineWeightDisplay ThisDrawing.preferences.LineWeightDisplay = True ' Define the new Dim3PointAngular object AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0 FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0 SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0 TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0 ' Create the new Dim3PointAngular object in model space Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint) ThisDrawing.Application.ZoomAll ' Read and display current dimension lineweight CurrentSetting = DimPointAngularObj.DimensionLineWeight Select Case CurrentSetting Case acLnWtByLayer: CurrentSetting = "ByLayer" Case acLnWtByBlock: CurrentSetting = "ByBlock" Case acLnWtByLwDefault: CurrentSetting = "ByDefault" Case Else End Select MsgBox "The dimension lineweight setting for this object is currently set to: " & CurrentSetting ' Change the dimension lineweight DimPointAngularObj.DimensionLineWeight = acLnWt100 ThisDrawing.Regen acAllViewports ' Read and display current dimension lineweight MsgBox "The dimension lineweight setting for this object is now set to: " & DimPointAngularObj.DimensionLineWeight ' Return previous lineweight setting ThisDrawing.preferences.LineWeightDisplay = oldLWSetting End Sub Visual LISP: (vl-load-com) (defun c:Example_DimensionLineWeight() ;; This example creates a Dim3PointAngular object in model space ;; and changes the dimension lineweight to a thicker value ;; using the DimensionLineWeight property (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq preferences (vla-get-Preferences doc)) ;; Turn on lineweight display so the changes can be seen (setq oldLWSetting (vla-get-LineWeightDisplay preferences)) (vla-put-LineWeightDisplay preferences :vlax-true) ;; Define the new Dim3PointAngular object (setq AngleVertex (vlax-3d-point 0 0 0) FirstPoint (vlax-3d-point 2 2 0) SecondPoint (vlax-3d-point 1 4 0) TextPoint (vlax-3d-point 6 6 0)) ;; Create the new Dim3PointAngular object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint)) (vla-ZoomAll acadObj) ;; Read and display current dimension lineweight (setq CurrentSetting (vla-get-DimensionLineWeight DimPointAngularObj)) (cond ((= acLnWtByLayer CurrentSetting)(setq CurrentSetting "ByLayer")) ((= acLnWtByBlock CurrentSetting)(setq CurrentSetting "ByBlock")) ((= acLnWtByLwDefault CurrentSetting)(setq CurrentSetting "ByDefault")) (setq CurrentSetting (itoa CurrentSetting)) ) (alert (strcat "The dimension lineweight setting for this object is currently set to: " CurrentSetting)) ;; Change the dimension lineweight (vla-put-DimensionLineWeight DimPointAngularObj acLnWt100) (vla-Regen doc acAllViewports) ;; Read and display current dimension lineweight (alert (strcat "The dimension lineweight setting for this object is now set to: " (itoa (vla-get-DimensionLineWeight DimPointAngularObj)))) ;; Return previous lineweight setting (vla-put-DimensionLineWeight DimPointAngularObj oldLWSetting) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 05:16
