获取文档的词典集合。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_Dictionaries() ' This example finds the current dictionary collection and ' adds a new dictionary to that collection. Dim dict As AcadDictionary Set dict = ThisDrawing.Dictionaries.Add("TEST") MsgBox "A new dictionary called " & dict.name & " has been added to the dictionaries collection.", vbInformation, "Dictionaries Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_Dictionaries() ;; This example finds the current dictionary collection and ;; adds a new dictionary to that collection. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq dict (vla-Add (vla-get-Dictionaries doc) "TEST")) (alert (strcat "A new dictionary called " (vla-get-Name dict) " has been added to the dictionaries collection.")) ) |
GMT+8, 2024-6-2 22:07
