指定对象的描述。 支持的平台:仅窗口 属性值只读:不;对象除外DynamicBlockReferenceProperty 类型:字符串 分配给对象的描述。 言论动态块参照属性的描述由块作者设置,无法编辑。 线型描述最多可包含 47 个字符。描述可以是注释或一系列下划线、点、短划线和空格,以显示线型图案的简单表示。 例子工 务 局: Sub Example_Description() ' This example returns the description of the active linetype. ' It then changes the description of the active linetype. Dim currDescription As String ' This example modifies the description of a linetype currDescription = ThisDrawing.ActiveLinetype.Description MsgBox "The description of the active LineType is: " & currDescription, vbInformation, "Description Example" ' Change the description of the active linetype ThisDrawing.ActiveLinetype.Description = "My favorite LineType" MsgBox "The new description of the active LineType is: " & ThisDrawing.ActiveLinetype.Description, vbInformation, "Description Example" ' Reset the description of the active linetype ThisDrawing.ActiveLinetype.Description = currDescription MsgBox "The description of the active LineType is reset to: " & ThisDrawing.ActiveLinetype.Description, vbInformation, "Description Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_Description() ;; This example returns the description of the active linetype. ;; It then changes the description of the active linetype. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; This example modifies the description of a linetype (setq currDescription (vla-get-Description (vla-get-ActiveLinetype doc))) (alert (strcat "The description of the active Linetype is: " currDescription)) ;; Change the description of the active linetype (vla-put-Description (vla-get-ActiveLinetype doc) "My favorite LineType") (alert (strcat "The new description of the active Linetype is: " (vla-get-Description (vla-get-ActiveLinetype doc)))) ;; Reset the description of the active linetype (vla-put-Description (vla-get-ActiveLinetype doc) currDescription) (alert (strcat "The description of the active Linetype is reset to: " currDescription)) ) |
GMT+8, 2024-6-11 05:19
