指定要附着到新图形的默认打印样式表。 支持的平台:仅窗口 属性值只读:不 类型:字符串 打印样式表具有 .ctb或 .stb扩展名,包括和定义打印样式。 言论如果使用与颜色相关的打印样式,则可以将此选项设置为在搜索路径中找到的任何与颜色相关的打印样式表以及值“None”。如果使用命名打印样式,则可以将此选项设置为任何命名打印样式表。 要设置与颜色相关的打印样式,请使用属性。PlotPolicy 例子工 务 局: Sub Example_DefaultPlotStyleTable() ' This example reads and modifies the preference value that ' specifies the default plot style table to attach to new drawings. ' ' Note: You may want to change the path of the new plot style table below. Dim ACADPref As AcadPreferencesOutput Dim CurrentFile As String Const NewFile = "c:\monochrome.ctb" ' Get the drafting preferences object Set ACADPref = ThisDrawing.Application.preferences.Output ' Read and display the current plot style table path CurrentFile = ACADPref.DefaultPlotStyleTable If CurrentFile = "" Then MsgBox "There is no current plot style table being used", vbInformation Else MsgBox "The current plot style table is: " & CurrentFile End If ' Use a new plot style table ACADPref.DefaultPlotStyleTable = NewFile ' Read and display the new plot style table path CurrentFile = ACADPref.DefaultPlotStyleTable MsgBox "The new plot style table is: " & CurrentFile, vbInformation End Sub Visual LISP: (vl-load-com) (defun c:Example_DefaultPlotStyleTable() ;; This example reads and modifies the preference value that ;; specifies the default plot style table to attach to new drawings. ;; ;; Note: You may want to change the path of the new plot style table below. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) (setq NewFile (strcat (vla-get-PrinterStyleSheetPath (vla-get-Files preferences)) "\\monochrome.ctb")) ;; Get the drafting preferences object (setq ACADPref (vla-get-Output preferences)) ;; Read and display the current plot style table path (setq CurrentFile (vla-get-DefaultPlotStyleTable ACADPref)) (if (= CurrentFile "") (alert "There is no current plot style table being used.") (alert (strcat "The current plot style table is: " CurrentFile)) ) ;; Use a new plot style table (vla-put-DefaultPlotStyleTable ACADPref NewFile) ;; Read and display the new plot style table path (alert (strcat "The new plot style table is: " (vla-get-DefaultPlotStyleTable ACADPref))) (vla-put-DefaultPlotStyleTable ACADPref CurrentFile) ) |
GMT+8, 2024-6-2 17:51
