指定新创建对象的默认打印样式名称。 支持的平台:仅窗口 属性值只读:不 类型:字符串 有效条目包括“按图层”、“按块”、“正常”或当前加载的打印样式中的任何样式名称。 言论此属性的初始值为“ByLayer”。 此属性仅在设置为 时可用。PlotPolicyacPolicyNamed 使用该属性查找当前打印样式。DefaultPlotStyleTable 注意:此属性的值存储在 DEFLPLSTYLE 系统变量中。
例子工 务 局: Sub Example_DefaultPlotStyleForObjects() ' This example reads and modifies the preference value that controls ' the default plot style name for newly created objects. ' When finished, this example resets the preference value back to ' its original value. Dim ACADPref As AcadPreferencesOutput Dim originalPolicyValue As Variant, originalValue As Variant, newValue As Variant ' Get the output preferences object Set ACADPref = ThisDrawing.Application.preferences.Output ' Set the default plot style to named plot styles originalPolicyValue = ACADPref.PlotPolicy ACADPref.PlotPolicy = acPolicyNamed ' Read and display the original value originalValue = ACADPref.DefaultPlotStyleForObjects MsgBox "The DefaultPlotStyleForObjects preference is: " & originalValue ' Toggle and display the DefaultPlotStyleForObjects preference If ACADPref.DefaultPlotStyleForObjects = "ByBlock" Then ACADPref.DefaultPlotStyleForObjects = "Normal" Else ACADPref.DefaultPlotStyleForObjects = "ByBlock" End If newValue = ACADPref.DefaultPlotStyleForObjects MsgBox "The DefaultPlotStyleForObjects preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.DefaultPlotStyleForObjects = originalValue MsgBox "The DefaultPlotStyleForObjects preference was reset back to: " & originalValue ACADPref.PlotPolicy = originalPolicyValue End Sub Visual LISP: (vl-load-com) (defun c:Example_DefaultPlotStyleForObjects() ;; This example reads and modifies the preference value that controls ;; the default plot style name for newly created objects. ;; When finished, this example resets the preference value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Get the output preferences object (setq ACADPref (vla-get-Output preferences)) ;; Set the default plot style to named plot styles (setq originalPolicyValue (vla-get-PlotPolicy ACADPref)) (vla-put-PlotPolicy ACADPref acPolicyNamed) ;; Read and display the original value (setq originalValue (vla-get-DefaultPlotStyleForObjects ACADPref)) (alert (strcat "The DefaultPlotStyleForObjects preference is: " originalValue)) ;; Toggle and display the DefaultPlotStyleForObjects preference (if (= (vla-get-DefaultPlotStyleForObjects ACADPref) "ByBlock") (vla-put-DefaultPlotStyleForObjects ACADPref "Normal") (vla-put-DefaultPlotStyleForObjects ACADPref "ByBlock") ) (setq newValue (vla-get-DefaultPlotStyleForObjects ACADPref)) (alert (strcat "The DefaultPlotStyleForObjects preference has been set to: " newValue)) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-DefaultPlotStyleForObjects ACADPref originalValue) (alert (strcat "The DefaultPlotStyleForObjects preference was reset back to: " originalValue)) (vla-put-PlotPolicy ACADPref originalPolicyValue) ) |
GMT+8, 2024-6-10 17:39
