为新图形或使用早期版本的 AutoCAD 创建的图形指定图层 0 的默认打印样式,这些图形从未以 AutoCAD 2000 或更高版本格式保存。 支持的平台:仅窗口 属性值只读:不 类型:字符串 您可以输入默认值“正常”,并输入当前加载的打印样式表中定义的任何打印样式。 言论此属性的初始值为“正常”。 此属性仅在设置为 时可用。PlotPolicyacPolicyNamed 使用该属性查找当前打印样式。DefaultPlotStyleTable 注意:此属性的值存储在 DEFLPLSTYLE 系统变量中。
例子工 务 局: Sub Example_DefaultPlotStyleForLayer() ' This example reads and modifies the preference value that controls ' the default plot style assigned to layers. ' When finished, this example resets the preference value back to ' its original value. Dim ACADPref As AcadPreferencesOutput Dim originalPolicyValue As Variant, originalValue As Variant, _ originalPlotStyleTableValue As Variant, newValue As Variant ' Get the output preferences object Set ACADPref = ThisDrawing.Application.preferences.Output ' Set the default plot style to named plot styles originalPolicyValue = ACADPref.PlotPolicy ACADPref.PlotPolicy = acPolicyNamed ' Read and display the original value originalValue = ACADPref.DefaultPlotStyleForLayer MsgBox "The DefaultPlotStyleForLayer preference is: " & originalValue originalPlotStyleTableValue = ACADPref.DefaultPlotStyleTable ACADPref.DefaultPlotStyleTable = "acad.stb" ' Toggle and display the DefaultPlotStyleForLayer preference If ACADPref.DefaultPlotStyleForLayer = "Style 1" Then ACADPref.DefaultPlotStyleForLayer = "Normal" Else ACADPref.DefaultPlotStyleForLayer = "Style 1" End If newValue = ACADPref.DefaultPlotStyleForLayer MsgBox "The DefaultPlotStyleForLayer preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.DefaultPlotStyleForLayer = originalValue MsgBox "The DefaultPlotStyleForLayer preference was reset back to: " & originalValue ' Restore the original plot style ACADPref.PlotPolicy = originalPolicyValue ACADPref.DefaultPlotStyleTable = originalPlotStyleTableValue End Sub Visual LISP: (vl-load-com) (defun c:Example_DefaultPlotStyleForLayer() ;; This example reads and modifies the preference value that controls ;; the default plot style assigned to layers. ;; When finished, this example resets the preference value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Get the output preferences object (setq ACADPref (vla-get-Output preferences)) ;; Set the default plot style to named plot styles (setq originalPolicyValue (vla-get-PlotPolicy ACADPref)) (vla-put-PlotPolicy ACADPref acPolicyNamed) (setq originalPlotStyleTableValue (vla-get-DefaultPlotStyleTable ACADPref)) (vla-put-DefaultPlotStyleTable ACADPref "acad.stb") ;; Read and display the original value (setq originalValue (vla-get-DefaultPlotStyleForLayer ACADPref)) (alert (strcat "The DefaultPlotStyleForLayer preference is: " originalValue)) ;; Toggle and display the DefaultPlotStyleForLayer preference (if (= (vla-get-DefaultPlotStyleForLayer ACADPref) "Style 1") (vla-put-DefaultPlotStyleForLayer ACADPref "Normal") (vla-put-DefaultPlotStyleForLayer ACADPref "Style 1") ) (setq newValue (vla-get-DefaultPlotStyleForLayer ACADPref)) (alert (strcat "The DefaultPlotStyleForLayer preference has been set to: " newValue)) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-DefaultPlotStyleForLayer ACADPref originalValue) (alert (strcat "The DefaultPlotStyleForLayer preference was reset back to: " originalValue)) ;; Restore the original plot style (vla-put-PlotPolicy ACADPref originalPolicyValue) (vla-put-DefaultPlotStyleTable ACADPref originalPlotStyleTableValue) ) |
GMT+8, 2024-6-10 16:51
