指定新布局和模型空间的默认输出设备。 支持的平台:仅窗口 属性值只读:不 类型:字符串 要使用的默认打印机的名称。 言论您可以指定为计算机配置的任何打印机,以及绘图仪配置路径中的任何 PC3 文件。 如果系统上没有设备,此属性将返回“无”。 例子工 务 局: Sub Example_DefaultOutputDevice() ' This example reads and modifies the preference value that controls ' the default output device for new layouts and model space. ' When finished, this example resets the preference value back to ' its original value. Dim ACADPref As AcadPreferencesOutput Dim originalValue As Variant, newValue As Variant ' Get the output preferences object Set ACADPref = ThisDrawing.Application.preferences.Output ' Read and display the original value originalValue = ACADPref.DefaultOutputDevice MsgBox "The DefaultOutputDevice preference is: " & originalValue ' Modify the DefaultOutputDevice preference ACADPref.DefaultOutputDevice = "DWG to PDF.pc3" newValue = ACADPref.DefaultOutputDevice MsgBox "The DefaultOutputDevice preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.DefaultOutputDevice = originalValue MsgBox "The DefaultOutputDevice preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_DefaultOutputDevice() ;; This example reads and modifies the preference value that controls ;; the default output device for new layouts and model space. ;; When finished, this example resets the preference value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Get the output preferences object (setq ACADPref (vla-get-Output preferences)) ;; Read and display the original value (setq originalValue (vla-get-DefaultOutputDevice ACADPref)) (alert (strcat "The DefaultOutputDevice preference is: " originalValue)) ;; Modify the DefaultOutputDevice preference (vla-put-DefaultOutputDevice ACADPref "DWG to PDF.pc3") (setq newValue (vla-get-DefaultOutputDevice ACADPref)) (alert (strcat "The DefaultOutputDevice preference has been set to: " newValue)) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-DefaultOutputDevice ACADPref originalValue) (alert (strcat "The DefaultOutputDevice preference was reset back to: " originalValue)) ) |
GMT+8, 2024-6-10 18:34
