获取对象所属的数据库。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_Database() ' This example references the Database object obtained from model space. ' Information from the Database object is then displayed Dim Database As AcadDatabase ' Attach to Database object Set Database = ThisDrawing.ModelSpace.Database MsgBox "We now have access to the properties and methods of the Database object!" ' Retrieve the number of Blocks in this database MsgBox "The number of Blocks in this database is: " & Database.Blocks.Count ' Release object Set Database = Nothing MsgBox "The Database object has been released!" End Sub Visual LISP: (vl-load-com) (defun c:Example_Database() ;; This example references the Database object obtained from model space. ;; Information from the Database object is then displayed (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Attach to Database object (setq database (vla-get-Database (vla-get-ModelSpace doc))) (alert "We now have access to the properties and methods of the Database object!") ;; Retrieve the number of Blocks in this database (alert (strcat "The number of Blocks in this database is: " (itoa (vla-get-Count (vla-get-Blocks database))))) ;; Release object (vlax-release-object database) (alert "The Database object has been released!") ) |
GMT+8, 2024-6-2 17:39
