指定要使用的自定义词典(如果有)。 支持的平台:仅窗口 属性值只读:不 类型:字符串 要使用的自定义词典。 言论此属性包含 AutoCAD 会话的自定义词典的驱动器、路径和文件名。 例子工 务 局: Sub Example_CustomDictionary() ' This example returns the current setting of ' CustomDictionary. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currCustomDictionary As String Dim newCustomDictionary As String Set preferences = ThisDrawing.Application.preferences ' Retrieve the current CustomDictionary value currCustomDictionary = preferences.Files.CustomDictionary MsgBox "The current value for CustomDictionary is " & currCustomDictionary, vbInformation, "CustomDictionary Example" ' Change the value for CustomDictionary newCustomDictionary = "TestCustomDictionary.cus" preferences.Files.CustomDictionary = newCustomDictionary MsgBox "The new value for CustomDictionary is " & newCustomDictionary, vbInformation, "CustomDictionary Example" ' Reset CustomDictionary to its original value preferences.Files.CustomDictionary = currCustomDictionary MsgBox "The CustomDictionary value is reset to " & currCustomDictionary, vbInformation, "CustomDictionary Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_CustomDictionary() ;; This example returns the current setting of ;; CustomDictionary. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current CustomDictionary value (setq currCustomDictionary (vla-get-CustomDictionary (vla-get-Files preferences))) (alert (strcat "The current value for CustomDictionary is " currCustomDictionary)) ;; Change the value for CustomDictionary (setq newCustomDictionary "TestCustomDictionary.cus") (vla-put-CustomDictionary (vla-get-Files preferences) newCustomDictionary) (alert (strcat "The new value for CustomDictionary is " newCustomDictionary)) ;; Reset CustomDictionary to its original value (vla-put-CustomDictionary (vla-get-Files preferences) currCustomDictionary) (alert (strcat "The CustomDictionary value is reset to " currCustomDictionary)) ) |
GMT+8, 2024-6-10 17:20
