将十字准线大小指定为屏幕大小的百分比。 支持的平台:仅窗口 属性值只读:不 类型:整数 一个介于 1 到 100 之间的正整数,表示要调整十字准线大小的总屏幕面积的百分比。 言论此属性的默认值为 5%。 允许的范围是整个屏幕的 1% 到 100%。在 100% 时,十字准线的末端是不可见的。如果尺寸减小到 99% 或更低,则十字准线的大小有限,并且十字准线的末端在移动到绘图区域的边缘时可见。 注意:此属性的值存储在 CURSORSIZE 系统变量中。
例子工 务 局: Sub Example_CursorSize() ' This example returns the current setting of ' CursorSize. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currCursorSize As Integer Dim newCursorSize As Integer Set preferences = ThisDrawing.Application.preferences ' Retrieve the current CursorSize value currCursorSize = preferences.DISPLAY.CursorSize MsgBox "The current value for CursorSize is " & currCursorSize, vbInformation, "CursorSize Example" ' Change the value for CursorSize newCursorSize = 10 preferences.DISPLAY.CursorSize = newCursorSize MsgBox "The new value for CursorSize is " & newCursorSize, vbInformation, "CursorSize Example" ' Reset CursorSize to its original value preferences.DISPLAY.CursorSize = currCursorSize MsgBox "The CursorSize value is reset to " & currCursorSize, vbInformation, "CursorSize Example" End Sub Visual LISP: (vl-load-com) (defun c:Example_CursorSize() ;; This example returns the current setting of ;; CursorSize. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current CursorSize value (setq currCursorSize (vla-get-CursorSize (vla-get-Display preferences))) (alert (strcat "The current value for CursorSize is " (itoa currCursorSize))) ;; Change the value for CursorSize (setq newCursorSize 10) (vla-put-CursorSize (vla-get-Display preferences) newCursorSize) (alert (strcat "The new value for CursorSize is " (itoa newCursorSize))) ;; Reset CursorSize to its original value (vla-put-CursorSize (vla-get-Display preferences) currCursorSize) (alert (strcat "The CursorSize value is reset to " (itoa currCursorSize))) ) |
GMT+8, 2024-6-11 05:53
