指定绘图仪配置名称。 支持的平台:仅窗口 属性值只读:不 类型:字符串 布局或打印配置要使用的 PC3 文件或打印设备的名称。 言论此属性不采用完全限定的路径,仅采用配置文件的文件名。使用该属性指定打印机配置文件的路径。PrinterConfigPath 在尝试更改属性之前使用该方法。RefreshPlotDeviceInfoConfigName 不要为属性分配“无”值。尝试这样做会导致意外行为。ConfigName 例子工 务 局: Sub Example_ConfigName() ' This example will add a new plot configuration to the current drawing. ' It will then list the plotter configuration file name for each Layout ' in the current drawing, change the configuration for Layout1 to "DWF Classic.pc3" ' and re-display the configuration information for the drawing. ' ' * Note: File names may differ on your system, so be prepared to change ' the configuration file name used in the example to a file that exists ' on your system. Dim Layouts As AcadLayouts, Layout As ACADLayout Dim msg As String Dim ACADPref As AcadPreferencesFiles Dim originalValue As Variant ' Get the files preferences object Set ACADPref = ThisDrawing.Application.preferences.Files ' Read and display the original value originalValue = ACADPref.PrinterConfigPath ' Get layouts collection from document object Set Layouts = ThisDrawing.Layouts ' Display current plotter configuration information GoSub DISPLAY_CONFIG ' Change plotter configuration file for "Layout1" Layouts("Layout1").ConfigName = "DWF6 ePlot.pc3" ' Display new plotter configuration information GoSub DISPLAY_CONFIG Exit Sub DISPLAY_CONFIG: msg = vbCrLf & vbCrLf ' Start with a space ' Format and display current directory for configuration files msg = msg & vbTab & "Directories that will be scanned for the plotter configuration files are: " _ & vbCrLf & vbTab & vbTab & originalValue & vbCrLf & vbCrLf ' Get the plotter configuration name of every layout in this drawing For Each Layout In Layouts ' Format for display msg = msg & vbTab & Layout.name & " is using configuration: " & Layout.ConfigName & vbCrLf Next ' Display paper units information MsgBox "The plotter configuration information used in the current drawing is listed below." & msg Return End Sub Visual LISP: (vl-load-com) (defun c:Example_ConfigName() ;; This example will add a new plot configuration to the current drawing. ;; It will then list the plotter configuration file name for each Layout ;; in the current drawing, change the configuration for Layout1 to "DWF Classic.pc3" ;; and re-display the configuration information for the drawing. ;; ;; * Note: File names may differ on your system, so be prepared to change ;; the configuration file name used in the example to a file that exists ;; on your system. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Get the files preferences object (setq ACADPref (vla-get-Files (vla-get-Preferences acadObj))) ;; Read and display the original value (setq originalValue (vla-get-PrinterConfigPath ACADPref)) ;; Get layouts collection from document object (setq Layouts (vla-get-Layouts doc)) ;; Format and display current directory for configuration files (setq msg "") (setq msg (strcat msg "Directories that will be scanned for the plotter configuration files are: \n" originalValue "\n")) ;; Get the plotter configuration name of every layout in this drawing (vlax-for Layout Layouts (setq msg (strcat msg "\n" (vla-get-Name Layout) " is using configuration: " (vla-get-ConfigName Layout))) ) ;; Display paper units information (alert (strcat "The plotter configuration information used in the current drawing is listed below.\n\n" msg)) ;; Change plotter configuration file for "Layout1" (vla-put-ConfigName (vla-Item Layouts "Layout1") "DWF6 ePlot.pc3") ;; Display new plotter configuration information ;; Format and display current directory for configuration files (setq msg "") (setq msg (strcat msg "Directories that will be scanned for the plotter configuration files are: \n" originalValue "\n")) ;; Get the plotter configuration name of every layout in this drawing (vlax-for Layout Layouts (setq msg (strcat msg "\n" (vla-get-Name Layout) " is using configuration: " (vla-get-ConfigName Layout))) ) ;; Display paper units information (alert (strcat "The plotter configuration information used in the current drawing is listed below.\n\n" msg)) ) |
GMT+8, 2024-6-10 22:03
