指定颜色索引。 支持的平台:仅窗口 属性值只读:不 类型:枚举acColor 默认颜色指定为。使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:acByLayer
言论没有额外的评论。 例子工 务 局: Sub Example_ColorIndex() 'This example draws a circle and 'returns the closest color index. Dim col As AcadAcCmColor Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2)) col.SetRGB 125, 175, 235 Dim cir As AcadCircle Dim pt(0 To 2) As Double Set cir = ThisDrawing.modelSpace.AddCircle(pt, 2) cir.TrueColor = col ZoomAll Dim retCol As AcadAcCmColor Set retCol = cir.TrueColor If col.ColorMethod = AutoCAD.acColorMethodByRGB Then MsgBox "Closest ColorIndex=" & col.ColorIndex End If End Sub Visual LISP: (vl-load-com) (defun c:Example_ColorIndex() ;;This example draws a circle and ;;returns the closest color index. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) (setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2)))) (vla-SetRGB col 125 175 235) (setq pt (vlax-3d-point 0 0 0)) (setq modelSpace (vla-get-ModelSpace doc)) (setq cir (vla-AddCircle modelSpace pt 2)) (vla-put-TrueColor cir col) (vla-ZoomAll acadObj) (setq retCol (vla-get-TrueColor cir)) (if (= (vla-get-ColorMethod col) acColorMethodByRGB) (alert (strcat "Closest ColorIndex=" (itoa (vla-get-ColorIndex col)))) ) (vlax-release-object col) ) |
GMT+8, 2024-6-10 17:46
