指定样条是打开还是关闭。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论闭合样条时,可使样条曲线两端相切连续。如果样条的起点和终点已经相同,则闭合样条会使样条在两点上相切连续。 打开闭合样条时,如果样条的起点和终点在关闭前相同,则此属性将样条返回到其原始状态。起点和终点保持不变,但会失去其切线连续性。 打开闭合样条时,如果样条的起点和终点在关闭前不同,则此属性将样条返回到其原始状态并删除切线连续性。 例子工 务 局: Sub Example_Closed() ' This example creates a polyline and then toggles the ' setting to Closed. Dim plineObj As AcadPolyline Dim closedState As String ' Create the polyline Dim points(8) As Double points(0) = 3: points(1) = 7: points(2) = 0 points(3) = 9: points(4) = 2: points(5) = 0 points(6) = 3: points(7) = 5: points(8) = 0 Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points) ' Set the closed property to True plineObj.Closed = True ' Close Polyline ThisDrawing.Regen (True) GoSub DISPLAY ' Open the PolyLine by setting the closed property to False plineObj.Closed = False ' Open Polyline ThisDrawing.Regen (True) GoSub DISPLAY Exit Sub DISPLAY: ' Retrieve and display the Closed property closedState = IIf(plineObj.Closed, "Closed", "Open") MsgBox "The new Polyline is: " & closedState, vbInformation, "Closed Example" Return End Sub Visual LISP: (vl-load-com) (defun c:Example_Closed() ;; This example creates a polyline and then toggles the ;; setting to Closed. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Create the polyline (setq points (vlax-make-safearray vlax-vbDouble '(0 . 8))) (vlax-safearray-fill points '(3 7 0 9 2 0 3 5 0 ) ) (setq modelSpace (vla-get-ModelSpace doc)) (setq plineObj (vla-AddPolyline modelSpace points)) ;; Set the closed property to True (vla-put-Closed plineObj :vlax-true) ;; Close Polyline (vla-Regen doc :vlax-true) ;; Retrieve and display the Closed property (setq closedState (if (= (vla-get-Closed plineObj) :vlax-true) "Closed" "Open")) (alert (strcat "The new Polyline is: " closedState)) ;; Open the PolyLine by setting the closed property to False (vla-put-Closed plineObj :vlax-false) ;; Open Polyline (vla-Regen doc :vlax-true) ;; Retrieve and display the Closed property (setq closedState (if (= (vla-get-Closed plineObj) :vlax-true) "Closed" "Open")) (alert (strcat "The new Polyline is: " closedState)) ) |
GMT+8, 2024-6-2 20:46
