指定圆的周长。 支持的平台:仅窗口 属性值只读:不 类型:双 圆的周长。 言论没有额外的评论。 例子工 务 局: Sub Example_Circumference() ' This example creates a Circle object in model space and ' returns the circumference of the Circle Dim circleObj As AcadCircle Dim centerPoint(0 To 2) As Double Dim radius As Double ' Define the new Circle object centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0 radius = 5# ' Create the Circle object in model space Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius) ThisDrawing.Application.ZoomAll MsgBox "The circumference of the new Circle is: " & circleObj.Circumference End Sub Visual LISP: (vl-load-com) (defun c:Example_Circumference() ;; This example creates a Circle object in model space and ;; returns the circumference of the Circle (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the new Circle object (setq centerPoint (vlax-3d-point 5 5 0) radius 5) ;; Create the Circle object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq circleObj (vla-AddCircle modelSpace centerPoint radius)) (vla-ZoomAll acadObj) (alert (strcat "The circumference of the new Circle is: " (rtos (vla-get-Circumference circleObj) 2))) ) |
GMT+8, 2024-6-11 01:06
