指定径向尺寸和直径尺寸的中心标记类型。 支持的平台:仅窗口 属性值只读:不 类型:枚举acDimCenterType
言论仅当尺寸线放置在圆或圆弧之外时,中心标记才可见。
注意:此属性将覆盖给定维度的 DIMCEN 系统变量的值。
例子工 务 局: Sub Example_CenterType() ' This example creates a diametric dimension in model space. ' It then changes the type of center for the dimension. Dim dimObj As AcadDimDiametric Dim chordPoint(0 To 2) As Double Dim farChordPoint(0 To 2) As Double Dim leaderLength As Double ' Define the dimension chordPoint(0) = 5#: chordPoint(1) = 3#: chordPoint(2) = 0# farChordPoint(0) = 5#: farChordPoint(1) = 5#: farChordPoint(2) = 0# leaderLength = 1# ' Create the diametric dimension in model space Set dimObj = ThisDrawing.ModelSpace.AddDimDiametric(chordPoint, farChordPoint, leaderLength) ZoomAll ' Set the center to be none dimObj.CenterType = acCenterNone dimObj.Update MsgBox "The dimension center type is set to none." ' Change the center type to center mark dimObj.CenterType = acCenterMark dimObj.Update MsgBox "The dimension center type is set to center mark." ' Change the center type to center line dimObj.CenterType = acCenterLine dimObj.Update MsgBox "The dimension center type is set to center line." End Sub Visual LISP: (vl-load-com) (defun c:Example_CenterType() ;; This example creates a diametric dimension in model space. ;; It then changes the type of center for the dimension. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq chordPoint (vlax-3d-point 5 3 0) farChordPoint (vlax-3d-point 5 5 0) leaderLength 1) ;; Create the diametric dimension in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimDiametric modelSpace chordPoint farChordPoint leaderLength)) (vla-ZoomAll acadObj) ;; Set the center to be none (vla-put-CenterType dimObj acCenterNone) (vla-Update dimObj) (alert "The dimension center type is set to none.") ;; Change the center type to center mark (vla-put-CenterType dimObj acCenterMark) (vla-Update dimObj) (alert "The dimension center type is set to center mark.") ;; Change the center type to center line (vla-put-CenterType dimObj acCenterLine) (vla-Update dimObj) (alert "The dimension center type is set to center line.") ) |
GMT+8, 2024-6-10 23:52
