指定多行文本是否具有背景填充。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论MText:此属性中包含的值是“特性”选项板中的“背景掩码”属性。 例子工 务 局: Sub Example_BackgroundFill() ' This example creates a circle and an MText object, and masks part of the ' circle with the MText object 'Draw a circle Dim circleObj As AcadCircle Dim CircleReference(0 To 2) As Double Dim radius As Double CircleReference(0) = 0 CircleReference(1) = 0 CircleReference(2) = 0 radius = 5 Set circleObj = ThisDrawing.ModelSpace.AddCircle(CircleReference, radius) ZoomAll MsgBox "A circle has been drawn." 'Create an MText object with the BackgroundFill property set to True Dim MTextObj As AcadMText Dim width As Double Dim text As String width = 10 text = "This is the text for the MText object" Set MTextObj = ThisDrawing.ModelSpace.AddMText(CircleReference, width, text) MTextObj.BackgroundFill = True ZoomAll End Sub Visual LISP: (vl-load-com) (defun c:Example_BackgroundFill() ;; This example creates a circle and an MText object, and masks part of the ;; circle with the MText object (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Draw a circle (setq CircleReference (vlax-3d-point 0 0 0) radius 0.5) (setq modelSpace (vla-get-ModelSpace doc)) (setq circleObj (vla-AddCircle modelSpace CircleReference radius)) (vla-ZoomAll acadObj) (alert "A circle has been drawn.") ;; Create an MText object with the BackgroundFill property set to True (setq width 5 text "This is the text for the MText object") (setq MTextObj (vla-AddMText modelSpace CircleReference width text)) (vla-put-AttachmentPoint MTextObj 5) (vla-put-InsertionPoint MTextObj CircleReference) (vla-put-BackgroundFill MTextObj :vlax-true) (vla-ZoomAll acadObj) ) |
GMT+8, 2024-6-10 17:35
