指定自动跟踪矢量的颜色。 支持的平台:仅窗口 属性值只读:不 类型:OLE_COLOR(常量)
言论此属性的默认颜色为。vbWhite 例子工 务 局: Sub Example_AutoTrackingVecColor() ' This example reads and modifies the preference value that controls ' the color of the AutoTrack vector. When finished, this example ' resets the preference value back to its original value. Dim ACADPref As AcadPreferencesDisplay Dim originalValue As Variant, newValue As Variant ' Get the display preferences object Set ACADPref = ThisDrawing.Application.preferences.DISPLAY ' Read and display the original value originalValue = ACADPref.AutoTrackingVecColor MsgBox "The AutoTrackingVecColor preference is: " & originalValue ' Modify the AutoTrackingVecColor preference by making it red ACADPref.AutoTrackingVecColor = vbRed newValue = ACADPref.AutoTrackingVecColor MsgBox "The AutoTrackingVecColor preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.AutoTrackingVecColor = originalValue MsgBox "The AutoTrackingVecColor preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_AutoTrackingVecColor() ;; This example reads and modifies the preference value that controls ;; the color of the AutoTrack vector. When finished, this example ;; resets the preference value back to its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Get the Display preferences object (setq ACADPref (vla-get-Display preferences)) ;; Read and display the original value (setq originalValue (vlax-variant-change-type (vla-get-AutoTrackingVecColor ACADPref) vlax-vbLong)) (alert (strcat "The AutoTrackingVecColor preference is: " (itoa (vlax-variant-value originalValue)))) ;; Modify the AutoTrackingVecColor preference by making it red (vla-put-AutoTrackingVecColor ACADPref (vlax-make-variant acRed 19)) (setq newValue (vlax-variant-change-type (vla-get-AutoTrackingVecColor ACADPref) vlax-vbLong)) (alert (strcat "The AutoTrackingVecColor preference has been set to: " (itoa (vlax-variant-value newValue)))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-AutoTrackingVecColor ACADPref (vlax-variant-change-type originalValue 19)) (alert (strcat "The AutoTrackingVecColor preference was reset back to: " (itoa (vlax-variant-value originalValue)))) ) |
GMT+8, 2024-6-10 22:56
