指定自动贴靠标记的颜色。 支持的平台:仅窗口 属性值只读:不 类型:枚举acColor
言论此属性的初始值为。acYellow 例子工 务 局: Sub Example_AutoSnapMarkerColor() ' This example reads and modifies the preference value that controls ' the color of the AutoSnap marker. When finished, this example resets ' the preference value back to its original value. Dim ACADPref As AcadPreferencesDrafting Dim originalValue As Variant, newValue As Variant ' Get the drafting preferences object Set ACADPref = ThisDrawing.Application.preferences.Drafting ' Read and display the original value originalValue = ACADPref.AutoSnapMarkerColor MsgBox "The AutoSnapMarkerColor preference is: " & originalValue ' Modify the AutoSnapMarkerColor preference by setting it to red ACADPref.AutoSnapMarkerColor = acRed newValue = ACADPref.AutoSnapMarkerColor MsgBox "The AutoSnapMarkerColor preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.AutoSnapMarkerColor = originalValue MsgBox "The AutoSnapMarkerColor preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_AutoSnapMarkerColor() ;; This example reads and modifies the preference value that controls ;; the color of the AutoSnap marker. When finished, this example resets ;; the preference value back to its original value. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Get the drafting preferences object (setq ACADPref (vla-get-Drafting preferences)) ;; Read and display the original value (setq originalValue (vla-get-AutoSnapMarkerColor ACADPref)) (alert (strcat "The AutoSnapMarkerColor preference is: " (itoa originalValue))) ;; Modify the AutoSnapMarkerColor preference by setting it to red (vla-put-AutoSnapMarkerColor ACADPref acRed) (setq newValue (vla-get-AutoSnapMarkerColor ACADPref)) (alert (strcat "The AutoSnapMarkerColor preference has been set to: " (itoa newValue))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-AutoSnapMarkerColor ACADPref originalValue) (alert (strcat "The AutoSnapMarkerColor preference was reset back to: " (itoa originalValue))) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 05:17
