指定在使用属性启用自动保存时创建的文件的路径。AutoSaveInterval 支持的平台:仅窗口 属性值只读:不 类型:字符串 自动保存文件的驱动器和路径。 言论注意:此属性的值存储在 SAVEFILEPATH 系统变量中。
例子工 务 局: Sub Example_AutoSavePath() ' This example returns the current setting of ' AutoSavePath. It then changes the value, and finally ' it resets the value back to the original setting. Dim preferences As AcadPreferences Dim currAutoSavePath As String Dim newAutoSavePath As String Set preferences = ThisDrawing.Application.preferences ' Retrieve the current AutoSavePath value currAutoSavePath = preferences.Files.AutoSavePath If currAutoSavePath = "" Then MsgBox "AutoSavePath is not currently set.", vbInformation, "AutoSavePath Example" Else MsgBox "The current value for AutoSavePath is " & currAutoSavePath, vbInformation, "AutoSavePath Example" End If ' Change the value for AutoSavePath newAutoSavePath = "C:\AutoCAD\" preferences.Files.AutoSavePath = newAutoSavePath MsgBox "The new value for AutoSavePath is " & newAutoSavePath, vbInformation, "AutoSavePath Example" ' Reset AutoSavePath to its original value preferences.Files.AutoSavePath = currAutoSavePath If currAutoSavePath = "" Then MsgBox "AutoSavePath is reset to Null.", vbInformation, "AutoSavePath Example" Else MsgBox "The AutoSavePath value is reset to " & currAutoSavePath, vbInformation, "AutoSavePath Example" End If End Sub Visual LISP: (vl-load-com) (defun c:Example_AutoSavePath() ;; This example returns the current setting of ;; AutoSavePath. It then changes the value, and finally ;; it resets the value back to the original setting. (setq acadObj (vlax-get-acad-object)) (setq preferences (vla-get-Preferences acadObj)) ;; Retrieve the current AutoSavePath value (setq currAutoSavePath (vla-get-AutoSavePath (vla-get-Files preferences))) (if (= currAutoSavePath "") (alert "AutoSavePath is not currently set.") (alert "The current value for AutoSavePath is " currAutoSavePath) ) ;; Change the value for AutoSavePath (setq newAutoSavePath "C:\\AutoCAD\\") (vla-put-AutoSavePath (vla-get-Files preferences) newAutoSavePath) (alert (strcat "The new value for AutoSavePath is " newAutoSavePath)) ;; Reset AutoSavePath to its original value (vla-put-AutoSavePath (vla-get-Files preferences) currAutoSavePath) (if (= currAutoSavePath "") (alert "AutoSavePath is reset to Null.") (alert (strcat "The AutoSavePath value is reset to " currAutoSavePath)) ) ) |
GMT+8, 2024-6-10 16:35
