指定要用作径向尺寸或引出线的自定义箭头的块。 支持的平台:仅窗口 属性值只读:不 类型:字符串 要用作引线箭头的块的名称。 言论注意:此属性将覆盖给定维度的 DIMLDRBLK 系统变量的值。
例子工 务 局: Sub Example_ArrowHeadBlock() ' This example creates a radial dimension object in model space ' and then alters the visible appearance (shape) of the arrowhead ' using the ArrowHeadBlock property. ' Use the ArrowHeadBlock property to set the arrowhead to an existing ' block object containing a custom Circle object Dim dimObj As AcadDimRadial Dim center(0 To 2) As Double Dim chordPoint(0 To 2) As Double Dim leaderLen As Integer Dim BlockName As String ' Define the dimension center(0) = 0#: center(1) = 0#: center(2) = 0# chordPoint(0) = 5#: chordPoint(1) = 5#: chordPoint(2) = 0# leaderLen = 5 ' Create the radial dimension in model space Set dimObj = ThisDrawing.ModelSpace.AddDimRadial(center, chordPoint, leaderLen) ZoomAll ' Set arrowhead type to user-defined to allow ' the use of a block as the new arrowhead 'dimObj.ArrowheadType = acArrowUserDefined dimObj.ArrowheadBlock = "CBlock" ZoomAll ' Read and display current arrowhead block name BlockName = dimObj.ArrowheadBlock MsgBox "The arrowhead block name for this object is: " & BlockName End Sub Visual LISP: (vl-load-com) (defun c:Example_ArrowHeadBlock() ;; This example creates a radial dimension object in model space ;; and then alters the visible appearance (shape) of the arrowhead ;; using the ArrowHeadBlock property. ;; Use the ArrowHeadBlock property to set the arrowhead to an existing ;; block object containing a custom Circle object (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq center (vlax-3d-point 0 0 0) chordPoint (vlax-3d-point 5 5 0) leaderLen 5) ;; Create the radial dimension in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimRadial modelSpace center chordPoint leaderLen)) (vla-ZoomAll acadObj) ;; Use the custom block as the new arrowhead, the block must exist in the drawing (vla-put-ArrowheadBlock dimObj "CBlock") (vla-ZoomAll acadObj) ;; Read and display current arrowhead block name (setq BlockName (vla-get-ArrowheadBlock dimObj)) (alert (strcat "The arrowhead block name for this object is: " BlockName)) ) |
GMT+8, 2024-6-10 18:42
