获取线条的角度。 支持的平台:仅窗口 属性值只读:是的 类型:双 线的角度(以弧度为单位)。角度测量从X轴开始,沿逆时针方向进行。 言论没有额外的评论。 例子工 务 局: Sub Example_Angle() ' This example adds a line in model space and returns the angle of the new line Dim lineObj As AcadLine Dim startPoint(0 To 2) As Double, endPoint(0 To 2) As Double ' Define the start and end points for the line startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0 endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0 ' Create the line in model space Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint) ThisDrawing.Application.ZoomAll MsgBox "The angle of the new Line is: " & lineObj.angle End Sub Visual LISP: (vl-load-com) (defun c:Example_Angle() ;; This example adds a line in model space and returns the angle of the new line (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the start and end points for the line (setq startPoint (vlax-3d-point 1 1 0) endPoint (vlax-3d-point 5 5 0)) ;; Create the line in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq lineObj (vla-AddLine modelSpace startPoint endPoint)) (vla-ZoomAll acadObj) (alert (strcat "The angle of the new Line is: " (rtos (vla-get-Angle lineObj) 2))) ) |
GMT+8, 2024-6-11 03:34
