启用备用单位的尺寸标注。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。False 注意:此属性覆盖给定维度的 DIMALT 系统变量的值。
例子工 务 局: Sub Example_AltUnits() ' This example creates an aligned dimension in model space and ' uses AltUnits to toggle the alternate dimension units on and off Dim dimObj As AcadDimAligned Dim point1(0 To 2) As Double, point2(0 To 2) As Double Dim location(0 To 2) As Double ' Define the dimension point1(0) = 0: point1(1) = 5: point1(2) = 0 point2(0) = 5: point2(1) = 5: point2(2) = 0 location(0) = 5: location(1) = 7: location(2) = 0 ' Create an aligned dimension object in model space Set dimObj = ThisDrawing.ModelSpace.AddDimAligned(point1, point2, location) ThisDrawing.Application.ZoomAll ' Toggle alternate unit display Toggle: Select Case MsgBox("Press OK to toggle the display of alternate dimensions", vbOKCancel) Case vbOK ' Toggle the alternate dimension display dimObj.AltUnits = Not (dimObj.AltUnits) ThisDrawing.Regen acAllViewports Case vbCancel Exit Sub End Select ' Display status of alternate units display If dimObj.AltUnits Then MsgBox "Alternate units display is on." Else MsgBox "Alternate units display is off." End If GoTo Toggle End Sub Visual LISP: (vl-load-com) (defun c:Example_AltUnits() ;; This example creates an aligned dimension in model space and ;; uses AltUnits to toggle the alternate dimension units on and off (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 0 5 0) point2 (vlax-3d-point 5 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) (vla-ZoomAll acadObj) ;; Toggle alternate unit display (setq originalValue (vla-get-AltUnits dimObj)) (vla-Regen doc acAllViewports) (alert "Toggling the display of alternate units.") ;; Toggle the display of trailing zeros for the alternate dimension tolerance value (vla-put-AltUnits dimObj (if (= originalValue :vlax-true) :vlax-false :vlax-true)) (setq newValue (vla-get-AltUnits dimObj)) (vla-Regen doc acAllViewports) (alert "Toggling the display of alternate units to original value.") (vla-put-AltUnits dimObj (if (= newValue :vlax-true) :vlax-false :vlax-true)) (vla-Regen doc acAllViewports) ) |
GMT+8, 2024-6-2 21:50
