确定符号名称是可以包含扩展字符集还是超过 31 个字符。 支持的平台:仅窗口 属性值只读:不 类型:布尔
言论此属性的初始值为。True 扩展符号名称最多可以包含 255 个字符和 A-Z、0-9、空格以及 Microsoft Windows 和 AutoCAD 未用于其他目的的任何特殊字符。 受限符号名称最多可包含 31 个字符和 A-Z、0-9、美元符号 ($)、下划线 (_) 和连字符 (-)。 此属性适用于存储在符号表中的非图形对象(例如线型和图层)的名称。 注意:此属性的值存储在 EXTNAMES 系统变量中。
例子工 务 局: Sub Example_AllowLongSymbolNames() ' This example reads and modifies the preference value that controls ' whether symbol names include extended character sets or more ' than 31 characters. ' ' When finished, this example resets the preference value back to ' its original value. Dim ACADPref As AcadDatabasePreferences Dim originalValue As Variant, newValue As Variant ' Get the user preferences object Set ACADPref = ThisDrawing.preferences ' Read and display the original value originalValue = ACADPref.AllowLongSymbolNames MsgBox "The AllowLongSymbolNames preference is set to: " & originalValue ' Modify the AllowLongSymbolNames preference by toggling the value ACADPref.AllowLongSymbolNames = Not (ACADPref.AllowLongSymbolNames) newValue = ACADPref.AllowLongSymbolNames MsgBox "The AllowLongSymbolNames preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.AllowLongSymbolNames = originalValue MsgBox "The AllowLongSymbolNames preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_AllowLongSymbolNames() ;; This example reads and modifies the preference value that controls ;; whether symbol names include extended character sets or more ;; than 31 characters. ;; ;; When finished, this example resets the preference value back to ;; its original value. (setq acadObj (vlax-get-acad-object)) ;; Get the drafting preferences object (setq ACADPref (vla-get-Preferences doc)) ;; Read and display the original value (setq originalValue (vla-get-AllowLongSymbolNames ACADPref)) (alert (strcat "The AllowLongSymbolNames preference is set to: " (if (= originalValue :vlax-true) "1" "0"))) ;; Modify the AllowLongSymbolNames preference by toggling the value (vla-put-AllowLongSymbolNames ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true)) (setq newValue (vla-get-AllowLongSymbolNames ACADPref)) (alert (strcat "The AllowLongSymbolNames preference has been set to: " (if (= newValue :vlax-true) "1" "0"))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-AllowLongSymbolNames ACADPref originalValue) (alert (strcat "The AllowLongSymbolNames preference was reset back to: " (if (= originalValue :vlax-true) "1" "0"))) ) |
GMT+8, 2024-6-2 21:17
