指定如何获取自动对齐点。 支持的平台:仅窗口 属性值只读:不 类型:枚举acAlignmentPointAcquisition
言论此属性的初始值为。acAlignPntAcquisitionAutomatic 例子工 务 局: Sub Example_AlignmentPointAcquisition() ' This example reads and modifies the preference value that controls ' how AutoAlignment points are acquired. When finished, this example resets ' the preference value back to its original value. Dim ACADPref As AcadPreferencesDrafting Dim originalValue As Variant, newValue As Variant ' Get the drafting preferences object Set ACADPref = ThisDrawing.Application.preferences.Drafting ' Read and display the original value originalValue = ACADPref.AlignmentPointAcquisition MsgBox "The AlignmentPointAcquisition preference is: " & originalValue ' Toggle and display the AlignmentPointAcquisition preference If ACADPref.AlignmentPointAcquisition = acAlignPntAcquisitionAutomatic Then ACADPref.AlignmentPointAcquisition = acAlignPntAcquisitionShiftToAcquire Else ACADPref.AlignmentPointAcquisition = acAlignPntAcquisitionAutomatic End If newValue = ACADPref.AlignmentPointAcquisition MsgBox "The AlignmentPointAcquisition preference has been set to: " & newValue ' Reset the preference back to its original value ' ' * Note: Comment out this last section to leave the change to ' this preference in effect ACADPref.AlignmentPointAcquisition = originalValue MsgBox "The AlignmentPointAcquisition preference was reset back to: " & originalValue End Sub Visual LISP: (vl-load-com) (defun c:Example_AlignmentPointAcquisition() ;; This example reads and modifies the preference value that controls ;; how AutoAlignment points are acquired. When finished, this example resets ;; the preference value back to its original value. (setq acadObj (vlax-get-acad-object)) ;; Get the drafting preferences object (setq ACADPref (vla-get-Drafting (vla-get-Preferences acadObj))) ;; Read and display the original value (setq originalValue (vla-get-AlignmentPointAcquisition ACADPref)) (alert (strcat "The AlignmentPointAcquisition preference is: " (itoa originalValue))) ;; Toggle and display the AlignmentPointAcquisition preference (if (= (vla-get-AlignmentPointAcquisition ACADPref) acAlignPntAcquisitionAutomatic) (vla-put-AlignmentPointAcquisition ACADPref acAlignPntAcquisitionShiftToAcquire) (vla-put-AlignmentPointAcquisition ACADPref acAlignPntAcquisitionAutomatic) ) (setq newValue (vla-get-AlignmentPointAcquisition ACADPref)) (alert (strcat "The AlignmentPointAcquisition preference has been set to: " (itoa newValue))) ;; Reset the preference back to its original value ;; ;; * Note: Comment out this last section to leave the change to ;; this preference in effect (vla-put-AlignmentPointAcquisition ACADPref originalValue) (alert (strcat "The AlignmentPointAcquisition preference was reset back to: " (itoa originalValue))) ) |
GMT+8, 2024-6-2 21:59
