指定活动布局。 支持的平台:仅窗口 言论没有额外的评论。 例子工 务 局: Sub Example_ActiveLayout() ' This example cycles through the documents collection ' and uses the ActiveLayout object to list the active layout ' for all open documents. Dim DOC As AcadDocument Dim msg As String ' If there are no open documents, then exit If Documents.Count = 0 Then MsgBox "There are no open documents!" Exit Sub End If msg = vbCrLf ' Start with a space ' Cycle through documents and determine the active layout name using the ' ActiveLayout property of the document object For Each DOC In Documents msg = msg & DOC.WindowTitle & ": " & DOC.ActiveLayout.Name & vbCrLf Next ' Display results MsgBox "The active layouts for the open drawings are: " & msg End Sub Visual LISP: (vl-load-com) (defun c:Example_ActiveLayout() ;; This example cycles through the documents collection ;; and uses the ActiveLayout object to list the active layout ;; for all open documents. (setq acadObj (vlax-get-acad-object)) (setq docs (vla-get-Documents acadObj)) (setq msg "") ;; Cycle through the Documents collection and determine the active layout name using the ;; ActiveLayout property of the document object (vlax-for each-doc docs (setq msg (strcat msg (vla-get-WindowTitle each-doc) ": " (vla-get-Name (vla-get-ActiveLayout each-doc)) "\n")) ) ;; Display results (alert (strcat "The active layouts for the open drawings are: \n\n" msg)) ) |
( 苏ICP备2022047690号-1 )
GMT+8, 2024-6-11 02:40
